Originally Posted by
paulsta
as i said in previous post there are 6 wires numbered 1 t0 6 that are all connect to a terminal block,,,,,,all you have to do is reverse wire number 5 and number 6.
It is nice you have found your answer, but in future if you need an informed answer from those that do not have the exact machine but with the proper information could possibly give a satisfactory answer, I suggest you offer as much information as possible such as to the type of motor, 1ph? 3ph? DC etc.
Info such as it has 6 leads and capacitor does not help all that much.
Even a pic would help a lot toward an answer.
Al.
