587,348 active members*
5,261 visitors online*
IndustryArena Forum > Maintenance in General > Maintenance DIY Discussion > Reversing King PDM-30 motor rotation
Results 1 to 5 of 5
    Dec 2004
    3
    Hi, i need to be able to reverse the rotation on my King drill mill, did a bit of research and it seems that if i reverse the wires feeding the magnetic field coils i will change the rotation, probleme is, i will have to take the motor apart in order to find those wires, i was hoping somebody on this forum could point me to what i should do.
    Comming out of the motor there are 6 wires all numbered 1 to 6.
    Any help or comments on is this possible or how i can get this done would be much apreciated.
    Thanks in advance
    Paul
    Dec 2011
    0
    I doubt you should have to take the motor apart to reverse the rotation.Can you say what type of motor is it. By that I mean is it a stepper motor,servo motor etc also can you say what is the power requirement for the motor, A.C or D.C. I believe this information can be obtain from the motor name plate.
    Dec 2004
    3
    The motor i'm trying to get going in reverse rotation is the one that is driving the spindle AC 220 volts 1 phase it also say's TYPE E on the sticker.
    There is a box screwed on to the motor, and all that is in there is a reset switch and the capacitor.
    The six wires comming out of the motor are all the same color and numbered 1 to 6.
    Paul
    Dec 2004
    3
    I found out how to reverse rotation, as i said in previous post there are 6 wires numbered 1 t0 6 that are all connect to a terminal block,,,,,,all you have to do is reverse wire number 5 and number 6.
    Dec 2003
    24223
    Quote Originally Posted by paulsta View Post
    It is nice you have found your answer, but in future if you need an informed answer from those that do not have the exact machine but with the proper information could possibly give a satisfactory answer, I suggest you offer as much information as possible such as to the type of motor, 1ph? 3ph? DC etc.
    Info such as it has 6 leads and capacitor does not help all that much.
    Even a pic would help a lot toward an answer.
    Al.
    Albert E.
  1. Polishing Aluminum using Burr King Vibra King 40
    By 07vistabluegt in forum MetalWork Discussion
    Last Post: 01-24-2011, 11:27 PM
  2. Reversing polarity of nema 23 motor
    By blackhauk90 in forum Stepper Motors / Drives
    Last Post: 01-08-2011, 04:28 PM
  3. reversing a ac drill press motor?
    By ZipSnipe in forum CNC Machine Related Electronics
    Last Post: 05-26-2009, 04:40 AM
  4. Motor missing steps then reversing ???
    By SScnc in forum Benchtop Machines
    Last Post: 09-27-2008, 09:11 AM
  5. reversing a ac servo motor
    By 69owb in forum Servo Motors / Drives
    Last Post: 09-02-2007, 02:49 PM
