587,086 active members*
2,831 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Wizards, Macros, & Addons > Limit switches,can i program them to just stop, and not punch out the E-stop in mach
    Dec 2008
    441
    Red face Limit switches,can i program them to just stop, and not punch out the E-stop in mach
    Hello.
    I run several of cnc machines at work.. (just started) :P
    And all of them does not punch out the e-stop button when they reach the end of an axis. At least not when I jog.
    Can i fix this in mach?
    And another question, when i run a program. For example a 3d relief. I can run up too 70mm / sec. the axis stop, and on the screen it says "Emergency mode" or something like that.
    Does anyone have a tip?
    Greetings from Robert.
    My second homebuilt cnc machine cnczone.com/forums/norwegian_club_house/123977-ombygget_cnc_-_gecko_540_a.html
    1) Use softlimits.
    2) Sounds like noise is triggering your estop.
    Dec 2008
    441
    Hello Gerry.
    Thanks for answering.
    1) How do i do that with the softlimit?
    2) I will try to change the cable from the VFD to spindle with one that are shielded (Yes I am a fool to have thought of that before)
    You set up your soft limits to stop just short of the physical limit switches. Watch the homing and limits video here:
    ArtSoft USA - Video Tutorials
    Dec 2008
    441
    Thank you i will come back if i have some more questions
    Dec 2008
    441
    Problem solved!
    works like a charm!
    Thanks again!
  1. Limit switches don't stop the machine
    By dfv in forum Mach Mill
    Last Post: 01-25-2011, 10:22 PM
  2. Got a Gecko G540, now which limit switches and E-Stop?
    By CNC Lurker in forum DIY CNC Router Table Machines
    Last Post: 12-06-2010, 10:13 AM
  3. BOSS 5 Limit switches don't stop movement
    By db427 in forum Bridgeport / Hardinge Mills
    Last Post: 09-09-2010, 09:15 PM
  4. DO I need LIMIT SWITCHES or E-stop??
    By max90272 in forum Stepper Motors / Drives
    Last Post: 07-14-2008, 05:45 PM
  5. Limit, Home and E Stop Switches
    By Mr.Chips in forum CNC Machine Related Electronics
    Last Post: 01-17-2007, 04:02 PM
