587,056 active members*
3,478 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > DynaTorch > Best place to mount gauges for oxy cutting?
    May 2011
    54
    I set up the oxy torches for the first time and liked the results, I need to do quite a bit of heavy cutting in the next few weeks and want to plan out where things go and have seen that some gauges are on the gantry? Is this because it is convenient to have them close to read frequently and are adjustments made often when cutting different plate sizes?
    Thinking of building a manifold with 2 oxy bottles or liquid possibly. I use propane for fuel.
    Any input from oxy users would be greatly appreciated,
    thanks in advance,
    Andy.
    Mar 2009
    924
    The closer the gauges are to the torch, the more accurate they read. Read your closest gauge to the torch to set psi's or flow. If you use flashback protectors, your pressures will need to be upped at least 10% sometimes as much as 25%
    Check out this thread:
    http://www.cnczone.com/forums/cnc_pl...iscussion.html
    There are some good references and ideas there.
    WSS
    www.metaltechus.com
    May 2011
    54
    Thanks WSS,
    you guys are dedicated to perfection, that thread took me a week and then some to read, just finished.
    i pulled the trigger on some files i had ready to cut using 1" hardox and i'm pleased with the results, just winged it but need to set up oxy system for regular use instead of using the shop cart. 30 secs PH, 1" lead, 15ipm I will post some pics soon.
    Andy.
    Mar 2009
    924
    Andy, glad you found it useful. you must of used acetylene to get 30sec PH with correct pressures. We used to do quite a bit of oxy, but is is maybe 20% of the cutting we do now. Propane is cheaper and less clean up if you do enough of it. The down side of propane is the miserably long PH (120-150 seconds on 1"), with the hi-lo system, we can hit 25sec cold and 15sec when the plate has warmed up a bit. You may find you need to have a different set of "tuning" figures for the slow speed, we eventually figured out that was needed. We would tighten it up for the slow speeds and set it back when doing 30ipm+. In the machine settings tab you can play around with it if you find some chatter in any direction. Usually, it would show up on X only moves. I am sure you know that grinding on 400 or 500 is for the birds! I did not mind chipping slag but The 9" grinder can stay on the shelf. LOL
    Merry Christmas!
    Tommy
    www.metaltechus.com
  1. what size motors for cutting photo mount board
    By mmcp42 in forum Hobby Discussion
    Last Post: 03-11-2011, 05:01 PM
  2. Cutting starts in wrong place...
    By Grip_Us in forum Techno CNC
    Last Post: 07-02-2010, 03:18 AM
  3. Software for ISO tolerances, fits and gauges
    By shgshg in forum News Announcements
    Last Post: 11-04-2008, 12:44 PM
  4. place to buy dremel cutting bits?
    By woox in forum Community Club House
    Last Post: 09-14-2008, 02:32 AM
  5. Using Gauges in CamSoft
    By Steve Etter in forum CamSoft Products
    Last Post: 11-12-2003, 08:58 PM
