587,529 active members*
3,375 visitors online*
Results 1 to 8 of 8
    Mar 2006
    113
    What loctite to use?
    This is a question about pneumatic connections.
    I have read to use:
    545
    5452
    275
    271
    Any comments or suggestions? I am putting together my compressor with a new filter and automatic drain.
    TIA
    Dan
    Jan 2010
    485
    Feb 2009
    6028
    Depends. Hydraulic fittings, high pressure, hydraulic low pressure, npt threads? Removable or not? I use 569 for high pressure fittings. The other one suggested for air/npt fittings.
    Mar 2006
    113
    Thanks for the input. It is an air compressor with npt threads a two stage filter (pre and coalescing) and an automatic drain. So pneumatic running at 120 psi. Not real sure what you mean by non removable. Once the system is together it would only be taken apart for repairs and maintenance. On the 565 it says it is used only for inert fittings. I am using mostly brass. Should I be using galvanized fittings?
    Quote Originally Posted by underthetire View Post
    Jul 2005
    12177
    Why not just use teflon tape?
    Feb 2009
    6028
    I'd just go to home depot and get rector seal for that application....much cheaper.
    Mar 2006
    113
    Thanks.
    Dec 2006
    18
    I generally like the 545 by far.
    271 or 275 are for thread locking, not sealing.
    There's also 565 which is thicker and messier. For pneumatic use 545 is quick and cleans up easy without the stick mess of 565.
    Quote Originally Posted by Geof View Post
    Teflon tape is slow and doesn't seal anywhere as well as a liquid sealant. To me it also looks amateurish in this day and age.
    Liquid sealants take 2-3 seconds to apply and are awesome if you are doing a lot of fittings.
  1. Correct Loctite for locking bolt head not thread?
    By Zathras in forum Mechanical Calculations/Engineering Design
    Last Post: 07-14-2010, 01:23 PM
  2. Loctite on gib screws?
    By TroyO in forum Benchtop Machines
    Last Post: 04-23-2010, 02:06 AM
