586,829 active members*
3,055 visitors online*
IndustryArena Forum > CAM Software > GibbsCAM > Drawing Module gear
Results 1 to 8 of 8
    Jul 2010
    62
    Drawing Module gear
    I am using Gibbscam, I have one problem with it , I am using mm, when I try to draw a gear I do not have option of Module, only DP. Does anybody know of a solution to this.
    I have to draw it on Peps cam which is about 20 years old.
    Aug 2006
    133
    Quote Originally Posted by murphyc1 View Post
    See if this helps.
    Gear Pitch Conversion
    Jul 2010
    62
    I have tried that , does'nt work as module is mm per tooth, DP is teeth per inch.
    Aug 2006
    133
    Ok. How about this:
    http://mdmetric.com/tech/modulegeardata.pdf
    Jul 2010
    62
    The problem is'nt conversion, I can draw it on other software and import it.
    Maybe if I had latest version of Gibbs it might be OK but the maintenance cost is to high.
    When I try to use Gibbs gear generator it wil not accept the correct data, it is not a major problem, just wondering is there a way around it.
    Jan 2009
    56
    DP is the number of teeth in 3.14" (PI) on the pitch diameter. Since PI is constant and unitless I am not sure it matter whether it is metric or not.
    Did you try converting the Module to DP?
    Jul 2010
    62
    Module gear
    DP is teeth per inch diameter not circumference, module is mm per tooth on diameter.
    The problem is not conversion, I just cannot get Gibbs to produce profile.
    Jan 2009
    56
    Had some time to think about this. If the program is asking for Pitch in mm. have you tried converting module to DP(in mm) by using this formula:
    number of teeth/pitch diameter (in mm) = DP (in metric)
    Seems a little strange BUT I checked the logic with some gears I have worked with and it does add up for coming up with a metric DP.
  1. Drawing a rack gear in Alibre
    By rogerfries in forum Uncategorised CAD Discussion
    Last Post: 09-22-2010, 05:01 PM
  2. Looking for metric module gear cutters
    By kae in forum MetalWork Discussion
    Last Post: 01-14-2010, 01:39 AM
  3. Replies: 13
    Last Post: 10-02-2009, 04:32 AM
  4. converting imported part drawing to mold drawing
    By msomerville in forum BobCad-Cam
    Last Post: 08-29-2008, 12:56 PM
  5. drawing gear
    By mostafabagheri in forum Uncategorised CAM Discussion
    Last Post: 02-03-2008, 12:50 PM
