587,818 active members*
3,212 visitors online*
IndustryArena Forum > CAD Software > Uncategorised CAD Discussion > Drawing a rack gear in Alibre
Results 1 to 6 of 6
    Mar 2008
    94
    I'm pretty new to Alibre, so don't be afraid to insult me by suggesting something that might seem obvious.
    I'm starting to design a plasma table using some parts I stripped off a heavy duty plotter. I'm drawing up the rails from the plotter and they have long rack gears on them. I don't need or want to draw the hundreds of the teeth and extrude a cut for them, but I want to do something to show the orientation of the teeth. Can I change the color of just one face, or apply a pattern to the surface of one face to indicate the teeth?
    Thanks!
    Jul 2007
    13
    Draw 1.5 of a tooth then use linear repeat.
    Mar 2008
    94
    I did the linear repeat and it is beautiful, but very slow and choppy now that there are 400+ teeth in it. I think I need a video card in this PC, currently it has integrated graphics
    Jul 2007
    13
    Try adjusting the display options in the properties of the drawing. You may get better results by making the drawing a little less sharp.
    Mar 2008
    94
    Thanks,
    I'll give that a try especially might help my laptop. For the desktop machine I just ordered a video card & some more memory. Should help
    Mar 2008
    94
    I installed a new Video card on Monday and WOW what a difference! everything just works so much better in Alibre. I thought it was fine before until this rack gear issue, but now it's so much better. Movements are all animated and smooth! If anyone else is using integrated graphics, I highly recommend getting a video card! I got a Quadro FX380LP $119 from Newegg. This is a relatively low end card, but I needed a Low profile card to fit my case.
  1. Gear rack for the Z ?
    By douglasco in forum Waterjet General Topics
    Last Post: 07-23-2008, 02:03 PM
  2. drawing gear
    By mostafabagheri in forum Uncategorised CAM Discussion
    Last Post: 02-03-2008, 12:50 PM
  3. alibre express or bobcad v22 for drawing
    By dgalaxy in forum Uncategorised CAM Discussion
    Last Post: 11-24-2007, 05:16 PM
  4. Spur Gear / Gear Rack
    By ckrantz in forum Linear and Rotary Motion
    Last Post: 12-07-2006, 06:06 AM
  5. rack gear
    By mniadna in forum DIY CNC Router Table Machines
    Last Post: 01-19-2005, 04:06 PM
