587,006 active members*
3,158 visitors online*
    Apr 2009
    8
    Robodrill File Loading problem
    I am trying to load a program into our robodrill and when I try to load it using the quick/nc it says "Registration of file is failed". I've had this problem before, but copy and pasted body of code into file that did load. This did not work this time. I tried .nc, .txt, no extenstion unformat in wordpad etc. Does anyone know how to fix this?
    Sean.
    Aug 2011
    2517
    is your error on a CNC machine or on a PC? It looks like a PC communication software problem not a CNC machine issue? If PC error what software are you using to transfer the CNC program?
  1. Loading XML File.
    By Ark1 in forum Mach Wizards, Macros, & Addons
    Last Post: 04-19-2014, 12:01 PM
  2. Loading a file into Fanuc 21M
    By idtkid in forum Fanuc
    Last Post: 09-25-2009, 08:57 AM
  3. Robodrill Problem
    By henry l. in forum Uncategorised MetalWorking Machines
    Last Post: 06-15-2009, 01:31 AM
  4. Robodrill Problem
    By henry l. in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-14-2009, 08:03 PM
  5. File loading issue
    By life3970 in forum Milltronics
    Last Post: 08-21-2008, 05:00 PM
