586,779 active members*
9,329 visitors online*
    Sep 2011
    moment and coefficient of friction
    Hello, new here and always learning and hope my question does not confuse everyone, for lack of my knowledge.
    I am working on the force calculations of the joints, (moment and coefficient of friction) needed for an articulated robot arm with five degrees of freedom, the end effecter is a bearing spindle.
    What I cannot find is the plunge, holding force of the spindle and spindle velocity min, max, optimal needed for milling various Woods and ferrous/non ferrous materials per bit size: so I can add these to the moment and coefficient of friction of the arm calculations.
    Any help in finding the sources for the information will be greatly appreciated!!
    Sep 2011
    Thank you for the great site, I had tried a search before posting a question to no avail but received an answer from the “similar threads” section at the bottom of the page below my redundant question!
    “CNC feed rates of materials” then was searched on the web, also MATLAB - The Language Of Technical Computing and Coefficients Of Friction.
    Thank you!!
  1. Coefficient of Friction
    By TZ250 in forum Mechanical Calculations/Engineering Design
    Last Post: 06-28-2008, 05:59 PM
  2. Moment calcs for Z axis assembly
    By guru_florida in forum Mechanical Calculations/Engineering Design
    Last Post: 01-22-2008, 08:44 AM
  3. Eureka moment (for me): Floating dust shoe (Pics)
    By IQChallenged in forum DIY CNC Router Table Machines
    Last Post: 07-09-2007, 12:16 AM
  4. moi3d (moment of inspiration)
    By smoker in forum Uncategorised CAM Discussion
    Last Post: 01-23-2007, 09:14 PM
  5. Friction welding
    By Geof in forum Welding Brazing Soldering Sealing
    Last Post: 08-08-2006, 08:51 AM
