587,128 active members*
3,152 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Rebuild Hurco Power Supply w/ PC Power Supply VMX30
Results 1 to 16 of 16
    Aug 2011
    12
    Made some progress today. Seems the machine has a 2 part problem. Only related to a power failure that happened last week. Killed the power supply and also corrupted WinMax (Hurco software).
    I did get the power supply to work so far. I will be posting photos. I used a PC power supply from Best Buy. I also found out that our Hurco does not use the -5 vdc or the PG signal wire.
    I also used a Phoenix Contact 5 amp 24vdc power supply(info here http://rd.phoenixcon.com/products/in...3127_00_en.pdf ). I had this one in house rather than ordering a 10 amp and having to wait. Hopefully, the 5 amp will be enough.
    Now onto the software issue...
    Jonathan M. DeLong
    www.JexMfg.com
    Feb 2010
    163
    Yes you're making progress. I've never used a winmax system myself. There's a procedure that can be used to reload the software - if you have the disks.
    About the PG and -5V: most industrial pc's don't use the PG ("Power Good") signal as they've usually got a VCC sensor on board tied into a watchdog timer. The -5V is leftover from the really old days, and isn't used by anything on moden computers except perhaps the sound. It's still required to be on the ISA bus so it's still provided out of the power supply. It was used as the die bias on the 8080 CPU's. (Man, the 8085 was a huge improvement: single voltage, single clock, not that ridiculous 4-phase clock input the 8080 needed!)
  1. How'd you supply your power supply?
    By cnczane in forum DIY CNC Router Table Machines
    Last Post: 08-28-2011, 11:13 AM
  2. controller power supply 115/230v OK for Australian power?
    By Momill in forum Australia, New Zealand Club House
    Last Post: 07-07-2011, 05:06 PM
  3. More power from switching power supply
    By R.thayer in forum CNC Machine Related Electronics
    Last Post: 03-11-2007, 02:03 AM
  4. Power Supply from a computer power supply
    By jmytyk in forum CNC Machine Related Electronics
    Last Post: 01-11-2006, 09:56 PM
