So I have a sherline 4 axis mill that has motors added to it. I have a breakout board and stepper motor drivers all set up with a power supply, and have the pinouts set as the documentation instructs in Mach3.
The first thing to note is that 3 of the motors are the same, flashcut cnc motors with 4 wires coming out of them. The other motor looks similar, but it doesn't have a brand name on it, and has 6 wires coming out, although only 4 are being used. The one motor that is different (Y axis) is the one working. The other 3 jump, but don't really turn. Also, when the power supply is on, the Y axis motor can't be turned by hand. The other 3 can be, whether the power is on or not.
I know nothing about how the motors are supposed to be setup, and have no documentation on them. Also, I have never worked with CNC machines before, and just started trying to figure this out a few weeks ago, a month at most. I do know not to cross A and B wires, but that's about it. Thanks for any help you can provide. I can post pics of the setup and motors if it will help.
