587,913 active members*
3,816 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Running 2 motors on the same axis
Results 1 to 4 of 4
    Nov 2003
    314
    How do you go about running two steppers on the same axis ? would you use the fourth axis on say a hobbycnc board and wire both in parrallel
    35538
    In TurboCNC, you can set both axis to be X. But I don't think the jog will work if you do that.
    Another option is 2 connect both axis step and direction to the same pins for both axis.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Aug 2004
    2849
    I believe xairflyer wants to run two steppers from one servo amp. If the servo amp can handle the additional current requirements you could parallel the winding of two identical motors....the big problem is that the motor characteristics must be identical....you may also find that if you are trying to drive to screws that are mechanicall coupled via a table/gantry, etc. you may run into some "racking" due to the variation in the screws and in the small difference in stepping speed due to some stepper tolerance variation....
    Why do you want to do this?
    35538
    I don't think so, because he asks if you would use the 4th axis on the driver board.
    Gerry
  1. 3 axis CNC Router with AC/DC Brushless motors (Need help with electronic Design)
    By StressedMech in forum CNC Machine Related Electronics
    Last Post: 05-15-2005, 05:26 PM
  2. Does anyone know of a controller board for synchronized stepper motors
    By Yellowbeard in forum Stepper Motors / Drives
    Last Post: 04-04-2005, 05:06 AM
  3. Looking for controller board for synchronized stepper motors
    By Yellowbeard in forum CNC Machine Related Electronics
    Last Post: 04-02-2005, 03:50 PM
  4. 3 axis setup: 2 motors work fine, 1 locks up
    By chozo in forum Stepper Motors / Drives
    Last Post: 11-04-2004, 02:57 AM
  5. Gantry/two motors per axis...how to configure
    By chozo in forum DIY CNC Router Table Machines
    Last Post: 08-28-2004, 02:50 AM
