587,370 active members*
3,330 visitors online*
    May 2011
    Question about Yag dpps 75w laser
    Ive got a question for you guys ,
    Im planning to engrave/mark hardcoat anodized aluminum , is 75w yag laser going to be sufficient to produce a nice bright logo on black anodized aluminum ?
    Veetek
    Jul 2008
    776
    More than enough
    Why use a YAg? a simple 20w co2 Galvo will do for anodised aluminium, a YAG will actually burn away the anodising cutting into the aluminium and exposing bare metal that can corrode , a c02 will leach the black dye from the anodising and actually leave the anodising intact
    Ask whoever is supplying your machine to do test samples so you know you arent buying the wrong/much more expensive type...
    May 2011
    Well , yes I was thinking about the co2 laser but my customer would like to get a brilliant white engraving on class III hardcoat anodized alu. Just making sure that 75 dpss yag is enough to go thru the hard anodize
  1. Question about laser power:
    By Lasertag in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-12-2011, 10:22 AM
  2. ULS 6.60 laser question???
    By KustomKoncepts in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-08-2008, 08:54 PM
  3. M-500 Laser Question
    By ebrandt in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-05-2007, 12:10 AM
  4. co2 laser question
    By cncadmin in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-10-2006, 07:39 PM
  5. Laser question
    By watzmann in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-02-2006, 05:21 PM
