586,553 active members*
3,416 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > What is the best router to cut this foam/rubber?
    Oct 2004
    198
    Talking What is the best router to cut this foam/rubber?
    Hi guys,
    I tried to cut this foam/rubber with a 30° endmill, then I tried a 45° endmill but as you can see it just tore the hell out of it.
    I also noticed the plastic ontop just melted around the edges.
    I've got a proper router on the way, so I tried to machine it in our VMC, I ran it at 8000 RPM.
    Could someone please advise what is the best style of router to machine this material?
    Apr 2005
    421
    Quote Originally Posted by Darc
    Hi guys,
    Try putting it in a freezer and then cutting it.
    Oct 2004
    198
    Hey that mightn't be as crazy as it sounds.........thanks
    Jun 2003
    453
    Take some reference cuts in an offcut area on your first attempt to make sure you can calculate the effects of thermal contraction. Let it thaw out and then measure it and see how much the dimensions change, scale the toolpath/cad drawing accordingly and you should be able to accurately cut it.
    Splint
    Mar 2005
    1136
    I know freezing is a standard way to cut rubber, is this common with foam rubber? did it work for you?
