587,322 active members*
3,074 visitors online*
Results 1 to 9 of 9
    May 2009
    Using USB JoyPad or game device with Mach3?
    Is it possible to use a cheap USB game device to control your Mach3 machine?
    The answer is yes!
    And it is freeware
    As a spare time project I wrote a plugin for Mach3 doing exactly that. It has just been updated to version 2 and now supports step jogging as well as continuous jogging with two joysticks.
    Buttons can be programmed using a Windows program to predefined functions or you can program them with your own script.
    The User manual is well illustrated and will make you up and running in no time...
    Read more and download User manual and plugin from MachSupport Forum:
    Hope you find this plugin usefull...
    Apr 2010
    Hi I have a PS3 Controller connected to my PC. I shows up in Control Panel and all the buttons work and the Joysicks move as expected.
    I have loaded your plugin and I think configured it correctly and have the continous jogging and stepm jogging working with the AL,Sl AR SR buttons.
    BUT I can't make any of the other buttons do anything at all.
    What am I missing or is this a bug?
    Cheers
    Bernie Walker
    Jan 2006
    2985
    I have played around with a game controller and mach. It has been a couple years but I think the controller had its own software in which you could specify which controller action send which command. You could map each button on the controller to a mouse or keyboard key (or key combination). You could setup a profile for each application you wanted to use the controller with and it would react appropriately based on which application was active. It sounds like you have largely repeated existing work. I think there is an existing game controller plugin on the machsupport downloads page as well. That may have been what I used, I really don't remember anymore, I gave it up due to a couple "Oh $h!t" moments when I let go of the button and it continued on with its rapid move.
    Matt
    May 2009
    Hi Bernie,
    Quote Originally Posted by BerniW1936 View Post
    Hi I have a PS3 Controller connected to my PC. I have loaded your plugin and I think configured it correctly and have the continous jogging and stepm jogging working with the AL,Sl AR SR buttons.
    Bernie Walker
    If you just installed the JoyPad.m3p plugin and configured the axes; Continuous and step jogging will work.
    Buttons are ignored for safety reasons by default. To activate the buttons you must first select a standard template with JoyPadSetup program and press Save.
    Close and reopen Mach3 to let the plugin read the newly saved button template - now buttons is activated as described in the User manual.
    Hope this helps.
    - Joakim
    Nov 2005
    14
    I have a problem. first the joypad is working find but I am not able to run the joypadsetup.exe I get an error
    Application failed to initialize properly (0xc0000135) press ok..........
    I have run it once tried replacing it delete and replace. Any ideas I want to have some of the other options is there another way to set them up.
    Edit: Runs fine on other computers.
    May 2009
    I looks like a .NET Framework problem - I found this link:
    [SOLVED] The application failed to initialize properly (0xc0000135)
    Referring to the same error code.
    Hope this will solve the problem.
    - Joakim
    Nov 2005
    14
    Joakim,
    I installed .NET Framework 1.1, 2, 3, 3.5 and then it worked Thanks for the point in the right direction.
    Jim
    http://www.microsoft.com/en-us/downl...ils.aspx?id=26 for 3.5 without internet
    Jun 2021
    Re: Using USB JoyPad or game device with Mach3?
    Thanks for sharing.
    Mar 2024
    To do this I think it takes a bit of good technique, this game is similar to https://modilimitado.io/pt/stumble-guys-apk they are really great
  1. New here, question on Joypad for jogging
    By jcizek in forum LinuxCNC (formerly EMC2)
    Last Post: 01-15-2011, 04:52 AM
  2. Joypad problems. HELP
    By flash319 in forum LinuxCNC (formerly EMC2)
    Last Post: 09-09-2010, 05:28 PM
  3. Controlling pan/tilt with joypad control
    By f-x in forum LinuxCNC (formerly EMC2)
    Last Post: 01-19-2010, 06:02 PM
  4. HELP to Setup - Mesa 5I20 + Joypad.hal -
    By TZak in forum LinuxCNC (formerly EMC2)
    Last Post: 02-02-2008, 11:43 PM
  5. Latest BDI with Joypad?
    By benedict in forum LinuxCNC (formerly EMC2)
    Last Post: 11-06-2007, 06:59 PM
