587,743 active members*
3,036 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Hurco Spindle Drive Swap
    Dec 2010
    28
    CAn anyone tell me if these two drives can be swapped: A06B-6055-H106 and AO6B-6055-H108? I have a BMC 30 and a BMC 50 both have seperate issues. Neither of them are running at the moment, I need at least one of them. I believe the drive may be the issue on the 30 and I know the drive on the 50 is good.
    I appreciate any advice anyone has.
    John
    Feb 2009
    6028
    It will work, but you would need to re-configure it. The H108 could smoke the motor on the smaller machine.
    Dec 2010
    28
    Thanks for the reply, any ideas on how to reconfigure it?
  1. Fanuc/Hurco Spindle Drive Problem
    By gregm1976 in forum Fanuc
    Last Post: 12-18-2013, 08:52 AM
  2. 1982 Seres 1, swap spindle innards?
    By nate in forum Bridgeport / Hardinge Mills
    Last Post: 01-20-2011, 02:50 PM
  3. HUrco BMC 30 spindle drive
    By xclr82xtc in forum Uncategorised MetalWorking Machines
    Last Post: 07-10-2010, 07:04 PM
  4. Spindle motor swap, or servo swap?
    By Chuck Reamer in forum Tormach Personal CNC Mill
    Last Post: 10-09-2007, 06:54 AM
  5. boss V ram spindle swap?
    By D.D.Machine in forum Bridgeport / Hardinge Mills
    Last Post: 07-05-2007, 04:53 PM
