587,486 active members*
3,616 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Lower Z axis in both directions when machining a single slot
Results 1 to 9 of 9
    Jul 2003
    138
    Hello, I am machining a single slot to a depth of .25". The Z axis is lower only in one direction, how do I program the slot operation to lower the Z axis in both directions.
    I could modify the g-code my self but I would like to accomplish this task in Mastercam.
    Thanks...Norman
    Mar 2005
    988
    Are you programming in 2D or 3D? Maybe the slot got rotated in the drawing by accident? Or you cut using 'Ramp Contour' without a finish pass?.......
    There's a few things that could've happened here. (hopefully not a butchered post)
    It's just a part..... cutter still goes round and round....
    Jul 2003
    138
    Sorry,I should have been more descriptive.
    Just imagine a single line as my drawing which I would like to machine to a depth of -.25" using a 3/16" flat end mill. I would simply like to go back and forth on that line dropping each time by .02" until I reach .25".
    My current configuration is using a contour which only drops the z axis in one direction taking twice as long to complete in comparison to cutting in both directions.
    I tried an open pocket but it needs an overlap % which when set to 0 produces no tool path.
    Any ideas... Thanks!
    Jun 2005
    305
    Greetings,
    As with anything else in MasterCam, there is more than one way to accomplish this.
    1. Physically create geometry to represent the center line of the exact
    toolpath you need.
    This way you can run it as a simple 3D contour with the "compensation type"
    set to off and when you chain the geometry, you turn the "plane mask" off.
    2. Create a vertical line at each end of the slot to represent the CENTER of your
    cutter and use the WIREFRAME, RULED toolpath. Once again, turn the
    "compensation type" to off.
    3. Create a vertical surface to represent the CENTER LINE of your cutter.
    Then FAKE it by creating a tool that is EXTREMELY small, such as .00001 diameter
    With example 1, you have to change the geometry to change the pass depth.
    With examples 2 and 3, you can easily modify the individual pass depths by changing
    the stepover value.
    The bad thing about these examples is, there is no easy way to change the
    plunge feedrate without doing it through the NCI file editor.
    I am sure other people will have other ways to do the same thing.
    Attached Files Attached Files
    ObrienDave. MasterCam since V6. Gcode since 1983.
    The nose you punch today may belong to the butt you have to kiss tomorrow.
    23
    Just do a regular contour toolpath. Turn off cutter compensation, make sure lead in/out is off. Set the depth to -.25 (abs.) (I am assuming your geometry is drawn at Z0, if it is actually drawn at z-.25, set depth to 0 Incremental). Set your contour type to ramp and click the Ramp button. Now set Ramp Motion to depth and set the depth to .02. You'll most likely want to Make a pass at final depth.
    Jun 2005
    305
    Greetings,
    Like I said, I am sure other people will have other ways to do the same thing.
    One of my favorite sayings is:
    Take 20 programmers and you're going to get 20 different ways to do the same thing.
    What counts is the end result and doing it in the least amount of TOTAL time.
    I added your example to the ZIP file.
    On a side note, I am honestly impressed with the quality of the help that the
    members of these forums provide without being rude or condescending.
    Proud to be a member.
    THANX!
    Jul 2003
    138
    Thank you!
    Jun 2005
    305
    Your welcome!
    Apr 2003
    1876
    Quote Originally Posted by ObrienDave
    Greetings,
    True, and Mastercam can usually give you as many different ways of doing the same thing.
    THANX!
    This is by far one of the most professional boards I frequent. (And not just cuz I work here.)
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
