587,828 active members*
2,555 visitors online*
Page 1 of 12 12311
Results 1 to 20 of 239
    15362
    CNC Router Build For A Friend
    Here is the start of a build for a friend
    This machine will be able to cut around a piece of material 12x18 with up to a
    1.00 dia cutter
    It will have Hiwin linear rails & ballscrews
    Motors & drives to be decided on, but most likely will be a servo system
    We will try to do as much as possible, Using manual machines,(Time Permitting) to show the different setups, to make the parts needed to build this machine
    Some of the material's needed in this photo
    Attached Thumbnails Attached Thumbnails Some of the Materials Needed for this Build.jpg
    Mactec54
    Nov 2004
    436
    Mactec,
    Looking good! You know, you could save yourself some machining time by just using double-stick tape to hold the rails on, and pistol drilling the holes for the ball screw end mount bearings.
    Rob
    Sep 2005
    1195
    dimension
    How big that rails?
    15362
    spoiledbrat
    If you look really close at the linear rails, that are in the photo they have no holes for mounting, so the the double sided tape, Is a great idea, & should hold them really well, As for a pistol drill, I'm sure it will get used
    Mactec54
    15362
    asuratman
    The Hiwin rails in the photo are 20mm & will be for the X axes the Y & Z axes will have 16mm rails
    Mactec54
    15362
    Today we will set up the manual mill to start machining the base frame
    This is a small Jet knee mill & was one of the first one's they sold, it has been a great little mill
    First we will Tram the spindle, to get it true to the table, & then we can start to machine the parts for the base
    The base frame is the most important part to get right, if this is not made well
    it will affect a whole machine
    Attached Thumbnails Attached Thumbnails Tram The Milling Machine Head-2.jpg   Tram The Milling Machine Head-3.jpg   Tram The Milling Machine Head-4.jpg   Tram The Milling Machine Head-5.jpg
    Mactec54
    Apr 2005
    253
    Quote Originally Posted by spoiledbrat View Post
    Mactec,
    Rob
    Tape? that sounds interesting, can you provide more details of what type of tape etc?
    Rob
    15362
    The machining of the base frame, the aluminum pieces,were first deburred & then mounted on the mill & machined parallel
    The 2 outside frame pieces, were milled for the linear rail mounting at the same time, The outside pieces are made from .750 Mic6 tooling plate
    Mactec54
    15362
    robe_uk
    spoiledbrat & myself have a Joke about the double-sided tape & the pistol drill, as we were advised by a manufacture, To use this to fix his machine they had messed up on
    It would be nice if there was a magical tape like this
    Mactec54
    Nov 2004
    436
    Look at that immaculate workshop...
    Have you ever done any work in there?
    Apr 2005
    253
    robe_uk
    ok drilling and tapping it is then
    Oct 2005
    2392
    Wow you're not kidding!
    I thought all those photos were 3D renderings until I zoomed in!
    Impressive.
    How on earth do you get your machine that funny silver colour instead the normal colour, you know...
    Brown.
    15362
    RomanLini
    That's how all my machines look,The work tables of a machine is very important to keep them in great condition, If you want to hold tight tolerances on the parts you make
    That machine is more than 10 years old, It is just a Standard Manual Jet knee Mill, no read-out, no power feed, (Just handles to crank) But I did fit a VFD, I have had servo motors on the X axes, but only for testing different motors
    I usually just clean up the area of,(chips swarf oil Etc)before I take the photos, to make them look better
    Mactec54
    15362
    spoiledbrat
    It's called a shop-vac it takes over!! I could lend it to you,It know's what to do, & does not need any training
    Mactec54
    Nov 2004
    436
    "It's called a shop-vac it takes over!! I could lend it to you,It know's what to do, & does not need any training "
    Probably has too many buttons to safely employ in this shop...
    Rob
    Apr 2007
    8082
    If my mills were that clean they would feel absolutely NAKED. They actually like having swarf and oil all over them.
    CarveOne
    CarveOne
    15362
    For drilling, tapping, & reaming dowel holes in the ends of the frame rails, a fixture was made to mount on the side of the Mill table
    The fixture was milled on the edges & then set up on the Mill table, the Key slot was cut
    90deg to the edges of the aluminum plate, the holes were then drill, reamed for dowels & some of the holes were tapped
    2 steel Keys were made for the mounting
    With the fixture mounted on the Mill, the dowels were fitted down one edge & a stop at the bottom, it then has
    2 Mitee-Bite clamps on the other side, to push & hold the parts up against the dowels, The ends were ready to get there holes done
    There are 2 reamed holes & 2 tapped holes in each end
    Attached Thumbnails Attached Thumbnails Edge Drilling Fixture-1.jpg   Edge Drilling Fixture-3 Mounting Keys.jpg   Edge Drilling Fixture with       Key mounted-4.jpg   Fixture For EndFrame-5 Drilling.jpg
    Mactec54
    15362
    CarveOne
    My machines would never feel naked, they are always making something,material being cut on them as well as losts of cutting oils Etc, The shop-vac sucks everything up for the photo shoots
    Mactec54
    Apr 2007
    8082
    CarveOne
    We're just teasing. It's a lot of work keeping one that clean. Mine get cleaned also, but fighting rust due to the local humidity is tough.
    CarveOne
    CarveOne
    15362
    CarveOne
    If you need a lub,anti rust, try this on your machines or anything you want to use it on,Even for cutting/tapping it works quite well, This will solve your humidity problems on your machines, The humidity is not to bad here in TN
    INOX Lube: inox-mx3 Multipurpose, Non-Toxic Lubricant
    Mactec54
Page 1 of 12 12311
  1. Noob - Helping friend use CNC router.
    By RandEE in forum Controller Cards
    Last Post: 03-25-2019, 09:47 PM
  2. Newbie - To build or not to build Router/Plasma Table
    By dfranks in forum Waterjet General Topics
    Last Post: 04-08-2011, 05:16 AM
