587,603 active members*
3,856 visitors online*
Results 1 to 20 of 24
    Jul 2009
    20
    Centroid Problems
    I have a SAJO knee mill with Centroid M400 controls. The servos are SEM DC, brushed units. I had a problem with the encoder on the y-axis. I ordered another and installed it. After the installation, the machine will not home. It starts attempting to home on the z-axis, which now says full power without motion, in other words it has lost position indication on that axis. It will not move the x, y, or z axis with the jog commands. Any ideas?
    Feb 2008
    280
    An encoder problem on one axis may prevent homing, but it will not prevent you from jogging the other axes. There is something else going on.
    The status message window in the upper right corner of the screen is your friend.
    Choose Slow, Incremental jog mode and press variously the X, Y and Z jog buttons. What messages appear in the status window? Do any of the axes move in either direction? Switch to Slow, Continuous jog mode and try each direction again. What messages appear in the status window this time?
    Before you try to home, make sure all three axes are well clear of their limit switches and hard stops. Power off and turn the pulleys by hand if you need to.
    When you try to home, and it says "411 Z axis(3) full power without motion", does the Z axis actually move (e.g. run away rapidly)? Or does it sit still? Or does it move under control at the usual slow jog speed until it reaches the switch or the end of travel, then give you the stall message?
    Assuming that none of the axes move at all when you try to jog them or home them, then you probably have a servo drive power problem. Perhaps you are not getting DC power to the VM terminals of your servo drive. Perhaps the limit switch cable between the RTK2 and the servo drive is loose (assuming this is a pre-2002 M400, not a newer M400S model).
    Is your control a pre-2002 model with a SERVO1 drive; a 2002-2004 M400S with a SERVO3IO drive; or a post-2004 M400S with a DC3IO drive? See Centroid Servo Drives and Field Guide to Centroid Controls, 1994-2010 - CNC Services Northwest for pictures if necessary.
    What software version do you have? The software version number is displayed on the F1/Setup screen.
    Jul 2009
    20
    Centroid Problems
    Here is what I have:
    SERVO1 3-3T on the servo drive
    Software Version CNC10 Mill V1.51
    On the servo drive, the three green and three red leds labeled USV, UV, DSF, Z, Y, and X are on, not sure what that means. I can hear the servos begin to move (clicking) and sometimes they do move very slightly before I get the "axis full power without motion" error.
    I see no loose cables anywhere. Is there a way to check for DC power to the servo board, or does the fact that the leds are lit mean it is getting power?
    Update: I checked the voltage on the VM terminal. It appears to be around 3.7 volts, although it starts higher and then settles down to 3.7 volts.
    Feb 2008
    280
    It sounds like you had your meter on AC volts.
    Voltage between the VM terminal and the adjacent "GND" terminal (actually the minus side of Vm, not grounded at all) should be around 110VDC. You need the meter on DC volts and a suitable range to check that.
    Having the green UV and USV LEDs lit is a strong indication that there is adequate voltage at the VM terminals.
    Locate the gray limit switch cable which runs from your RTK2 PLC unit to the limit switch header of the SERVO1 drive. Unplug it from the SERVO1 drive. Locate the eight DIP switches on the SERVO1 drive, just below where the limit switch cable was plugged in. Make note of their current positions (very likely they should all be toggled down towards the board). Switch them so they are all up away from the board. This will defeat the limit switch inputs to the servo drive, telling it that all switches are okay. Power up and see if you can jog all axes in both directions.
    If you can jog okay with the limit switches defeated, then you have a problem with the gray cable connection between the RTK2 PLC and the servo drive. Inspect for damage, and try cleaning the connections at both ends with electronic contact cleaner. Plug the cable back in and return the DIP switches to their original positions.
    If you have adequate power at the VM terminals; have no drive fault indications; and cannot jog even with the limits defeated, then you probably have a servo drive failure of some kind and will need to have the board repaired or swapped.
    For a guide to the cable connections, see: http://www.cncsnw.com/ServoLogicPM.htm.
    Jul 2009
    20
    Centroid Problems
    No, I tried two different meters and both did the same. They were on VDC.
    Either way, today when I started up the unit prior to trying your suggestions, the machine homed on the x and z axis, which is what it would not do since changing the y axis encoder. It still moves as if it is getting no position feedback. The y axis begins motion at full speed and then stops, with the same error as before. Maybe I did not install the new encoder correctly. I just removed the old encoder and unplugged the cable. Bolted up the new encoder and plugged in the cable. Maybe there is more to it than that. Do you have a procedure for encoder replacement?
    Feb 2008
    280
    Go to the PID configuration screen: F1/Setup, F3/Config, "137", F4/PID.
    In the lower center of the screen there is a table of live status information about the axes. Look for a column labeled "Abs Pos". This is the position of each axis, in encoder counts.
    Press Emergency Stop in and turn your motor by hand. You should see Y counting up and down by 8000 counts per turn of the motor. If it is not counting at all, or counting inconsistently, then you have a problem with your encoder, cable, or connections.
    If it counts consistently 8000 counts per turn, but when you try to move the axis under power you get a brief jump opposite the commanded direction and a "410 Y axis(2) position error" message, then you have the encoder polarity reversed. Swap the channel A wires with the channel B wires, or just exchange one pair (e.g. swap A with /A).
    Jul 2009
    20
    Centroid Problems
    Thanks for the help. It appears that I do have a consistent 8000 counts per revolution on the y axis and I'm getting the "410 Y axis(2) position error" , as you suspected.
    Now, how to fix it. Tell me more on how to reverse the polarity. My encoder connection is a flat, thin connector that just plugs into the other half from the servo motor. I'm not sure what you mean by swap A with /A or do I have to disassemble the connector?
    Feb 2008
    280
    It is fairly easy to swap the encoder polarity if you have the right tools and supplies. It is possible to do it without the right tools and supplies if you are intimately familiar with crimp-on inserted-pin type connectors.
    I would guess that your new encoder is a Dynapar F18, like that pictured here: Encoders Used on Centroid Controls. If you pull the BLU and BLU/BLK wires out of positions 1 and 2 of the C-Grid connector, exchange them, and put them back, then the encoder will count the opposite direction.
    The crimp pins have a tab on one side that clicks into a cutout in the black plastic housing when the pin is fully inserted. If you press the tab down (e.g. with the tip of a jeweler's screwdriver or a bent paperclip) then you can pull the pin out.
    If you do not then replace the pin with a new one (see "right tools and supplies" above), then you need to carefully bend the tab back into shape so that it latches properly when you reinsert it. Otherwise the pin may push back when you try to plug it into the mating connector.
    An alternative solution is to reverse the polarity of the motor power (plus and minus armature leads) coming out of terminals 3 and 4 at the bottom of the servo drive.
    You can do that as a quick test: if you leave the encoder as it is and reverse the polarity of the power, you should find that the axis moves under control without errors (but moves in the wrong direction). If you still have problems that way, then reversing the encoder won't help either.
    If you decide to swap the power polarity as the permanent fix, then you also need to swap the plus and minus limit switch wiring connections; swap the limit switch and home switch numbers for that axis on the Machine Configuration -> Motor Parameters menu; and toggle "Direction Reversal" for that axis on the Machine Configuration -> Motor Parameters menu.
    Jul 2009
    20
    Centroid Problems
    OK, I swapped the polarity on the encoder. Yeah! The y-axis is alive!
    Problem is that the y-axis moves in the wrong direction and never finds the home switch. My guess is that the encoder polarity needs to be put back the way it was and reverse polarity to the servo motor by swapping terminals 3 and 4 as suggested earlier.
    Jul 2009
    20
    Centroid Problems
    I switched the encoder polarity back as it originally was and swapped the leads on terminals 3 and 4 of the servo drive. The y-axis now moves as it should and the machine did home, although it took a few attempts as it kept tripping the limit switch 2-3 times, but I would jog back and it eventually homed. Now I think I have a similar issue with the x-axis, in that it moves opposite what I think it should. X+ should be moving the table to the left, but the machine calls that X-. Is the procedure the same? Will or could there be limit switch issues?
    Feb 2008
    280
    When was the last time you saw this machine working correctly (including correct directions) on all axes? Is this machine new to you? Has it seen some undocumented modifications or repairs?
    Motors and limit switches generally don't rewire themselves spontaneously. Software configurations (e.g. the Direction Reversal setting on the Machine Configuration screen) don't generally change themselves spontaneously either.
    It sounds like you are starting from a completely unknown condition. Do you have a local Centroid dealer and service technician who can help you through the process of checking axis directions, limit switch wiring, limit switch number assignments, and anything else that might have gotten changed at the same time? If so, you should hire him to come in and check it over thoroughly.
    Jul 2009
    20
    Centroid Problems
    I purchased the machine from a guy in New Jersey. It worked fine when I got it, but within a couple of days, the encoder in the y-axis went out. I thought it was a bad servo motor and sent it out to a repair shop. They said the motor was fine and it needed an encoder, which would cost $1000. I got to checking around and found I could purchase and encoder for around $150, so I did and installed it myself. When I talked to centroid, they closest guy around was in Alabama. I'm in SE Georgia and didn't want to pay some guy travel time both ways to install an encoder. The machine has sat for some time waiting for other projects to get caught up on. Maybe Centroid has someone closer than 8-10 hours away now. Anyway, does it really matter if the x-axis works in the opposite direction as long as I know that it does?
    Any thoughts on why the y-axis goes to the end of travel limit switch several times before finding home? Perhaps the home limit and the end of travel limit are too close to each other?
    Feb 2008
    280
    Machines with Centroid DC-servo controls generally don't have separate home switches. Does yours? Maybe yours has an old home switch that is not used at all, and not wired to anything, with the machine homing off the limit switch?
    The usual homing direction on the Y axis is Y+ (saddle towards you). The usual sequence is to move out toward the limit just until the limit switch trips; immediately back off until the limit switch clears again; then continue backing off until the encoder's index pulse comes around.
    If yours is running all the way across the limit switch, then you probably have a switch position problem.
    You can use the PLC diagnostic display (Alt-I from the main screen) to watch the state of the switch(es). The Y limits are usually inputs 3 and 4. If you did not need to set Direction Reversal to achieve correct motor movement, then the minus switch (saddle towards column) should be INP3 and the plus switch (saddle towards you) should be INP4. If you needed to set Direction Reversal to achieve correct motor movement, then the minus switch should be INP4 and the plus switch should be INP3.
    First make sure that the axis direction is correct: jogging Y+ should move the saddle towards you; jogging Y- should move the saddle away from you. If it is not correct, then go to the Machine Configuration -> Motor Parameters table and toggle Direction Reversal for that axis, either from N to Y or from Y to N.
    While you are on the Machine Configuration -> Motor Parameters screen, verify that you have the limit and home switch numbers entered correctly, per the previous description. If you ended up with Direction Reversal = N for the Y axis, then the limit and home switch numbers should read 3 4 3 4. If you ended up with Direction Reversal = Y for the Y axis, then the limit and home switch numbers should read 4 3 4 3.
    Once you have it moving the correct direction, then use the Alt-I PLC Diagnostic display to find out whether the plus and minus switches are actually wired to the correct inputs. If they are not, then swap the wires on plug H3 on the RTK2 PLC unit. H3 is the upper 12-pin orange Phoenix plug on the right side of the middle board. Counting from the top, terminals 5 and 6 go to INP3 and terminals 7 and 8 go to INP4.
    All the same procedures apply to the X axis limit switches. If you need to toggle Direction Reversal for the X axis, then you need to check the order of the limit inputs (1 2 1 2 with Direction Reversal off, 2 1 2 1 with Direction Revesal on) and you need to verify that the correct switches are wired to inputs 1 and 2. Inputs 1 and 2 are on the top four terminals of H3.
    Your Y limit switch may also be dirty, sticky, or filled with coolant, so that it does not trip and clear consistently. However, in that case you usually get "407 ... limit tripped" errors while trying to home.
    Jul 2009
    20
    Centroid Problems
    I'm not sure how to post a photo, but my limit switches have two separate bumpers or stops at each end of travel that are mounted on an aluminum raceway, each is adjustable. It appears that each limit switch has a set of 4 contacts. Maybe I'll try to post up a photo, as some of the diagrams on the limit switches might tell you something. I'll see what I need to do to post a photo.
    Jul 2009
    20
    Feb 2008
    280
    I think if you look at the wiring and the PLC Diagnostic display, you will find that only two of the four switches are actually used.
    What is the control serial number (6000-series number on the back of the console and on the door of the electrical cabinet)?
    Jul 2009
    20
    Centroid Problems
    You are probably correct, the limit switches may have been on the Sajo mill prior to the Centroid control being installed. My guess is this was a tracer mill as you can mount several milling heads on it at the same time. In fact I have a second head.
    The serial number is 6126 and I sent the control back in to have it upgraded to Linux operating system (new motherboard, I think). I don't exactly remember why, but that is what Centroid recommended. I also purchased the DP-4 and TT-1.
    If the limit switches are as you suspect, and judging by the way the x-axis homes (which is exactly how you describe it - hitting the limit switch and then moving in the opposite direction), then I don't understand why the y-axis did this a couple of times and stopped rather than homing. After a couple of jogs and re-homing it finally got the y-axis homed.
    It still makes me think the x-axis must have been installed, or at least operated in the opposite direction as shown in the centroid manual because I have not done anything on the other axes. Maybe Centroid did something when the control was sent in for upgrade?
    Feb 2008
    280
    However it came to be as it is, you now have enough information to get all the axes moving the correct directions and to get the limit switches to match those directions.
    Yes, it does matter that you have the X axis moving the correct direction if you plan to program parts in the normal manner. If you have Y moving correctly, but X reversed, then everything you cut will be a mirror image of what you programmed and what the graphic preview shows.
    Perhaps the original owner had both axes running backward, which would result in a correct part, rotated around 180 degrees. I suppose someone might do that if he could never get his head around the idea that the jog arrows represent tool movement and not table movement.
    You can use the Alt-I PLC Diagnostic display to see if your Y limit switches promptly snap from Green to Red and back when you trip and release them by hand.
    If the switch does not respond promptly and cleanly, then you need to clean or replace it.
    Aug 2011
    407 Y+ limit(#4) tripped
    hi someone here could help me with this isue
    i have this error on my screen on the middle of work
    i am running any g-code file and then stop the machine with this message
    i move the switch by hand to cleaned it and seems like keep workiing
    but this thing is happening several times
    so any one here could tell me what to do to fix the isue
    i hope understand what is my problem ?
    by the way i using CNC-motion machine with HSD Spindle
    any help thank
    Feb 2008
    280
    You probably have a loose connection or damaged wire, somewhere between the Y axis limit switch and the PLC unit.
  1. Problems with Centroid M400
    By glbreil in forum Centroid CNC Control Products
    Last Post: 12-12-2023, 05:46 PM
  2. Centroid & MPG Problems
    By Marty_Escarcega in forum Centroid CNC Control Products
    Last Post: 10-15-2011, 03:22 PM
  3. BP Series I accuracy problems - Centroid controls
    By turbostang in forum Bridgeport / Hardinge Mills
    Last Post: 11-22-2007, 06:27 AM
  4. Offline Centroid Intercon Problems
    By jime in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-05-2006, 11:20 PM
  5. Centroid M-400 Problems
    By Acinch in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-04-2006, 10:03 PM
