587,475 active members*
3,706 visitors online*
    Exclamation MATSUURA MC-510VG ATC alarm
    Hello,
    I write you in hopes that you will help me to solve the problem on machines MATSUURA MC-510VG system YASNAC300
    Sensor is not able to find the first tool . We are old sensor replaced with new ones.But now, I need guidance on how to insert current number of tool in
    the tool screen as NEXT TOOL, because the machine still does not count tools.
    The column NEXT TOOL is empty, do not write anything, the magazine on manual controls can be run. the MDI mode is unable to run.
    We have alarm
    6616 CYCLE START LOCK IS BEING APPLIED
    and 6147 A TOOL No. IS BEING SET ON THE SCREEN TOOL SETTINGS
    this means that we need a procedure how to put the current number of tool pot in the number of diagnostic tools, or parameters where it would be write.
    unfortunately when buying a machine I have not received the necessary documentation so I asked you if someone please send me on the mail address the maintenance manual,operator manual
    and electric scheme,if is possible.
    Or just write me the procedure how to fix it
    type MATSUURA MC-510VG
    SNo 10432
    MNF. Year 1999
    System YASNAK 300
    Best regards,
    Boroja Slobodan
    [email protected]
    Exclamation
    STILL NEED HELP ON THIS PROBLEM. PLEASE!
    Feb 2008
    138
    Re: MATSUURA MC-510VG ATC alarm
    Did you ever get that figured out? it was in the user manual I believe
  1. matsuura alarm 4650
    By davidval67 in forum Controller & Computer Solutions
    Last Post: 10-19-2012, 02:36 PM
  2. helps with alarm:400, 424, matsuura
    By victorcnc in forum CNC Machining Centers
    Last Post: 03-09-2011, 02:15 AM
  3. help matsuura alarm!!!!!
    Last Post: 03-08-2011, 02:07 AM
  4. Looking for NSK Linear Bearings for Matsuura MC-510VG
    By dadelmann in forum Uncategorised MetalWorking Machines
    Last Post: 08-18-2010, 07:25 PM
  5. Matsuura MC-760-DC alarm 61
    By brad63av in forum Uncategorised MetalWorking Machines
    Last Post: 05-15-2008, 06:35 PM
