586,655 active members*
3,122 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > High Speed Air Spindle on Bridgeport Boss 8 R2E3?
    Jul 2005
    9
    Hello,
    I have been pondering using a high speed air spindle on my original Bridgeport Boss 8 R2E3 milling machine (just won one on eBay). The problem is that there is a spindle interlock that requires the spindle to be on or all axis feeds will be inhibited. The manual states that an emergency stop condition will be initiated if the spindle contactor drops out. I would like to mount the air spindle in a collet tool holder in the mill spindle, so obviously the mill spindle can't spin (at least if I want the air lines to stay connected). Has anyone ever used a secondary spindle on an old mill like this with the original controls?
    Thanks in advance,
    Joe
    Aug 2010
    109
    you should be able to fool the beast into thinking the spindle is on by adding a switch accross the auxillary contact on the contactor that tells the machine the spindle is running. should be easy to find in the schematics. hope this helps
  1. Need help with Bridgeport Boss 8 Series 2 R2E3
    By clue1005 in forum Bridgeport / Hardinge Mills
    Last Post: 12-17-2009, 06:32 PM
  2. Ayuda con Bridgeport Boss 8 R2E3
    By joanpim in forum Spanish
    Last Post: 03-20-2009, 11:09 PM
  3. bridgeport II/r2e3 boss 8
    By whaley in forum Mechanical Calculations/Engineering Design
    Last Post: 01-02-2008, 06:02 AM
  4. Bridgeport R2E3 with Boss 8
    By John Bennett in forum Bridgeport / Hardinge Mills
    Last Post: 09-17-2005, 01:35 AM
  5. Bridgeport R2E3 with Boss 8
    Last Post: 04-06-2005, 04:06 PM
