587,745 active members*
2,753 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > X axis works fine but Y axis direction is erratic
    Jan 2008
    I have a Kelig cnc system on a DIY router table. The X axis seems to be working fine but the Y axis direction is unpredictable. Sometimes it moves in the correct direction, stops and reverses itself. Sometimes goes in the same direction regardless of which jog button I press.
    This is a DIY project running a trial version of Mach3, on an old laptop... Just trying to get things working before I invest more money.
    Any ideas,, why would the motor change directions?
    Thanks. Swampbud1
    :drowning:
    possibly weak voltage on the direction pins? measure the voltage on the direction pin while jogging back and forth. It should be 0V in one direction, and 5V in the other direction.
    You could also try increasing the dir pulse width in motor tuning.
    Jan 2008
    When pressing Y+ the DRO increases, then the motor will reverse, but the DRO will continue to increase.
    Thanks for the info.
    Aug 2010
    No Laptop for Mach
    Gerry is correct...probably voltage issues at the laptops LPT port....
    Artsoft recommends NOT using a laptop for Mach3....
    I would try a desktop if you can.
    HTH
    Jeff
    Mar 2009
    624
    99% sure it will be the laptop causing it, my laptop does exactly the same if using the PP. I use the smooth stepper with laptop. Thou you can buy a cheap desktop for the same money as SS.
    I live in a damp enviroment so need to bring computer in warmer conditions and the laptop/ss combo works best for me.
  1. Only Y works correct X don't work Z works one direction only
    By jdgbadenhorst in forum Hobbycnc (Products)
    Last Post: 06-10-2012, 09:54 PM
  2. Erratic Z axis action
    By Sky Gazer in forum Chinese Machines
    Last Post: 10-05-2010, 04:30 AM
  3. erratic z axis
    By endgrainguy in forum CNC Machine Related Electronics
    Last Post: 11-12-2009, 04:51 PM
  4. Upgraded to 4.0, now only X axis works??
    By Mueller in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-04-2005, 04:23 PM
  5. 3 axis setup: 2 motors work fine, 1 locks up
    By chozo in forum Stepper Motors / Drives
    Last Post: 11-04-2004, 02:57 AM
