586,655 active members*
2,804 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Hitachi HT 20 CNC Lathe "turret index time over alarm" after battery change
    Oct 2006
    60
    My maintainance guy changed the batteries with the power off and now when I start the machine I get a "turret index time over alarm" I can jog the machine and zero return it but when I go to index the turret it will unclamp but it doesn't index. I have tried the turret alarm reboot proceedure holding the "feed hold" "select" and "main spindle stop" buttons all at once then pushing the "stand by" button. Still no luck. I can also unclamp the turret with the "rotory spindle stop" and "main spindle stop" buttons depressed at the same time then clamp the turret with the "call light" button. Hey Machtool or anyone else do you have a solution for this one? Machtool if you get this one I might have to put you on my payroll. I have six Hitachi lathes that are getting old.
    Mar 2009
    1982
    have you backup of parameters? or backup of original initial parameters?
    Oct 2006
    60
    Quote Originally Posted by Algirdas View Post
    Yes I have a back up of current parameters
    Aug 2008
    20
    I have the same problem
    Quote Originally Posted by surfit View Post
    I have the same problem. so I need you help can you say how to resolve this problem.
  1. Replies: 2
    Last Post: 09-10-2018, 09:21 PM
  2. Index to "Epoxy-Granite machine bases" thread
    By walter in forum Epoxy Granite
    Last Post: 12-02-2011, 05:45 AM
  3. Disabled "Lathe Index" command
    By vadim_m in forum EdgeCam
    Last Post: 02-19-2009, 12:23 PM
  4. Battery powered "flaps"
    By JetGirl in forum Mechanical Calculations/Engineering Design
    Last Post: 12-03-2008, 06:17 PM
  5. Fanuc 18t Turret alarm "1110"
    By senna95 in forum Fanuc
    Last Post: 10-18-2006, 05:03 PM
