I have seen where these type machines coming from china have cast iron fine in the bottoms of the gear boxes and inside the spindles quil. If you want a quiet and longer lasting machine I advise to take the brand new machines and power wash the insides of the gear box and spindles. Then re lube and reset them up as needed. Although the fine iron will pass through the bearings and gears with minimal damage, over time it will destroy the bearings. I broke this my first rule and myself had to go through the gear box and spindle replacing bearings and redoing everything. My gear box was so far gone that I HAD to go belt drive. Now my machine is much better than a stocker but !
Don
IH v-3 early model owner
