587,019 active members*
4,016 visitors online*
    Oct 2010
    Sherline rotary table on a 3 axis mill.
    Hello everybody.
    New here and this is my first post. Hope I’m in the right forum. I have a Sherline 3 axis (flashcut motors/xylotex board) mini mill running Mach3. I want to run Sherline rotary table, but have only 3 axis controller. Is it possible to disconnect X axis (I don’t need it for what I want to do) and hook up rotary table to that axis? If it is possible what do I need to change in configuration? Rotary table I intend to use is a Sherline 4" CNC rotary table with stepper motor P/N 8730.
    Thank you for your help.
    Glad.
    Dec 2010
    In Mach3 change your x axis to the a axis and hook up your r-table to the x axis. Go into config and click on ports then click on motor outputs and x out the x axis. Then click on the axis and change the step and direction numbers of the x axis to the a axis.
    Apr 2004
    5742
    In the most common configuration
    the rotary table's axis would be parallel to the X axis. So you'd disable the Y axis to power the A axis, not X. You would need a way to lock the Y axis at the Y=0 position, though, since if that axis isn't powered up, it will float freely, and could move off position in response to cutting forces.
    Andrew Werby
    ComputerSculpture.com — Home Page for Discount Hardware & Software
  1. DIY Rotary Axis on Sherline Mill.
    By mgjones in forum Benchtop Machines
    Last Post: 02-23-2010, 06:27 PM
  2. Sherline rotary table threading
    By MechanoMan in forum Benchtop Machines
    Last Post: 07-08-2009, 11:23 PM
  3. Adapter for Sherline rotary table
    By diamondback21 in forum Taig Mills / Lathes
    Last Post: 04-13-2009, 11:26 AM
  4. Sherline CNC rotary table adaptation
    By uptoolateman in forum Benchtop Machines
    Last Post: 02-06-2009, 09:48 PM
  5. SHERLINE rotary table
    By ACME in forum Benchtop Machines
    Last Post: 11-17-2004, 05:15 AM
