587,012 active members*
3,442 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Waterjet General Topics > Need Help Understanding Sheetcam Gcode Output
Results 1 to 2 of 2
    Sep 2005
    287
    Hi All,
    I'm learning the gcode which is output from Sheetcam for my plasma cutting
    table. I have a touch off Z-axis for referencing the torch height to the top of
    the material before each cut. I'm using the "MP3000-DTHC-SmlArcFix" post
    processor.
    Here's the first few lines of the gcode:
    N0030 G21 (Units: Metric)
    N0040 G53 G90 G40
    N0050 F1
    N0060 (Part: Sheetcam Tryout - Square)
    N0070 (Process: Outside Offset, VISIBLE, T1: Plasma, 2 mm kerf)
    N0080 M06 T1 F2000 (Plasma, 2 mm kerf)
    N0090 G00 Z12.7000
    N0100 X857.4000 Y942.6000
    N0110 G28.1 Z12.70
    N0120 G92 Z0.0
    N0130 G00 Z0.1370
    N0140 G92 Z0.0
    N0150 G00 Z5.0000
    N0160 M03
    Questions:
    Why is F1 (1mm per minute ?) inserted in line N0050. It's correctly set at 2000
    mm/min three lines later.
    What is the meaning of having a tool change on line N0080. I'm a beginner to
    this but I can't see any purpose to this, I mean there is no tool change. I
    would have expected just the feed rate to be set and that's it.
    Line N0090 says rapid the Z-axis to 12.7 but at this point the Z-axis position
    is not known, it hasn't been referenced / homed. With a floating Z-axis on a
    plasma cutter the homing is the touch-off and is the top of the material, and
    this is not done until after this starting on line N0110.
    I think I've got the rest of the gcode worked out but the above has me stumped
    at present.
    Thanks,
    Keith
    Jul 2005
    2415
    Check the same post on the Yahoo CandCNCSupport Forum. Answered in detail
    TOM caudle
    www.CandCNC.com
  1. Solidcam output weird Gcode
    By kn6398 in forum Solidworks
    Last Post: 03-19-2009, 01:55 AM
  2. Running a gcode output file in the computer
    By Palafox in forum Uncategorised CAM Discussion
    Last Post: 06-10-2008, 11:56 PM
  3. lots of extraneous Z commands in sheetcam output
    By mbwittig in forum SheetCam
    Last Post: 05-04-2007, 08:44 AM
  4. Replies: 0
    Last Post: 03-10-2005, 07:46 PM
  5. does deskam only output metric gcode?
    By july_favre in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-23-2004, 09:44 PM
