586,690 active members*
3,051 visitors online*
Thread: Hoss's G0704
Page 237 of 344 137187227235236237238239247287337
Results 4,721 to 4,740 of 6871
  1. #4721
    Nov 2012
    220
    replacement motor
    Hoss, I was looking around and found this motor (see link below) and was wondering if you thought it would be good for a BF20/G0704? I was thinking about using a KBVF-14 or a KBVF-26D to control it.
    AC & DC Motors, Universal Motors | Groschopp Motors
    There is a torque curve available on the mfg website. They also have a 3d model of the motor available.
    Graham
  2. #4722
    Jun 2012
    that's correct.
    but couple years too short still.
  3. #4723
    May 2013
    Ill try to figure out how to post some tomorrow after I awake..
  4. #4724
    I'd ask the manufacturer of that motor what they suggest for driving it, a more typical sensorless vector vfd might be a better choice. The motor looks like a nice fit for the mill.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  5. #4725
    Jul 2010
    60
    Ill attempt to add the pics of the lights I suggested.
    Attachment 184832
    Attachment 184834
    hope this works.
    oh yeah, they plug right into any wall outlet and they have a switch on the magnetic base.
  6. #4726
    Jun 2011
    279
    Those lights are pretty sweet! I will have to get one of those on my router so I can see what is going on.
    Chris
  7. #4727
    Nov 2012
    220
    Quote Originally Posted by hoss2006 View Post
    Hoss
    Thanks for getting back to me Hoss and sorry to keep bothering you. I think I will run the factory motor until it quits then try this one.
  8. #4728
    Nov 2007
    980
    Quote Originally Posted by recordingwhiz View Post
    Attachment 184832
    Attachment 184834
    hope this works.
    Thank you, that seems to be a good bit of light, and the adjustability makes it very handy as well, thanks for sharing-
    Dave
    Dave->..
  9. #4729
    Those lights look nice, thanks for sharing.
    Been busy outside, now have access ramps to the front of the house.:banana:
    Later this summer I'll have some concrete work done to get access up to the driveway to get to my truck.
    Hoss
  10. #4730
    Nov 2009
    4415
    Oh no Hoss has felt the sun again. Where are you? Sunbathing?
    A lazy man does it twice.
  11. #4731
    Yeah, working on getting a good base. lol
    It's nice to sit out on the deck with my morning coffee again.
    Hoss
  12. #4732
    Nov 2007
    980
    Hoss
    Dave->..
  13. #4733
    May 2013
  14. #4734
    Mar 2012
    77
    [nomedia="http://www.youtube.com/watch?v=6vhhSoWHE9w"]YouTube - G0704 Power Drawbar Test.wmv[/nomedia]
    Why in your video is there an exhaust sound at 2:10, then the PDB movement at 2:13. Not sure what the exhaust sound is. Thanks.
  15. #4735
    I said in the video the solenoid valve wasn't hooked up yet, I was testing it by using an air nozzle to blow into each line, the exhaust noise is the air escaping.
    Hoss
  16. #4736
    The newer power drawbar is better, you can see how it works in this video.
    Hoss
  17. #4737
    Mar 2012
    77
    Hoss
    OK, got it, thanks!
  18. #4738
    Mar 2012
    77
    Hoss
    OK, yes, great! So, given your depth of knowledge on this, maybe you can short circuit my learning curve here! I have a new SX3 that I'm finishing CNC'ing now. I just acquired a 4" bore / 4" stroke SINGLE-stage double-acting Bimba cylinder on eBay. I figured if direct-acting didn't work, I could use a levered setup like you did on one of your machines. I guess with 100psi, I'd get 1257 lbs in the direct-acting configuration. I'm using this for TTS. Is it certain that I'd need to do a levered setup? Also, I am having trouble finding out exactly how the bellevilles are stacked onto the spindle. Could you please point me to a link, where somebody has done it for the SX-3?
    Thank you!
  19. #4739
    Don't have any bookmarks for sx3 pdb's but search youtube, I know there are some.
    I use a stack of 3 pairs of bellevilles in series as shown here.
    Shop Info
    Direct acting with your cylinder would be good for light duty like I did on the X2 if you lock your quill though you have much more stroke than needed, 1/2 inch is usually plenty.
    You could use that stroke, as you mentioned with a lever setup similar to my X2, to get much more force but you'd want that force with the floating type pdb to avoid unnecessary strain on the bearings and quill lock.
    Hoss
  20. #4740
    Mar 2012
    77
    I had actually been to your site, and learned about bellevilles from there - thanks for your most excellent work, and sharing it with all of us. Very awesome of you! So, in other words, ()()(). So F1/D6? From where did you acquire the Belleville's?
    So, 1250 lbs +/- good for light duty. Great information. The Z-bot/Hoss levered design looks good, but requires a little more time/effort. I am hoping to get something in place quickly, so maybe I'll do it the first way, then make the parts for the levered design, then change it up later on, after using the mill to make the parts for the levered design. I had wanted to find a Fabco-air 4" multi-stage cylinder, but there have been none for anything significantly below retail that I could find, at least for the last little while.
    By the way, is there a problem with only using a portion of the full stroke? Like if I only use 1/2", wouldn't that be fine? With respect to the "floating-type pdb", do you mean the bracket that springs up as the drawbar is depressed? What exactly is happening there? If I want 1800 lbs, for example, to fully depress the bellevilles, but there is only 1250 lbs, then am I not decreasing the downward force by having springs absorb some of it? (It is very likely that I'm just not hearing you right)
    Finally, with respect to the strain on the bearings and quill lock, is the quill locked permanently while using the mill in CNC mode?
    Thanks for all your help/advice!
  1. Hoss's G0704
    By hoss2006 in forum Benchtop Machines
    Last Post: 03-25-2016, 12:48 AM
  2. Another G0704 conversion - Hoss's plans - LinuxCNC control
    By otto_pjm in forum Benchtop Machines
    Last Post: 11-14-2013, 06:26 PM
  3. G0704 Y axis Thrust Bearing Block and Stepper mount from Hoss Plans
    By LLDesigns in forum RFQ (Request for Quote)
    Last Post: 12-12-2012, 02:49 AM
  4. RFQ A few parts from Hoss G0704 Plans
    Last Post: 10-21-2011, 09:13 PM
  5. Hoss does it again!
    By tooManyHobbies in forum Benchtop Machines
    Last Post: 11-01-2008, 06:29 AM
