587,302 active members*
3,318 visitors online*
Thread: Hoss's G0704
Page 287 of 344 187237277285286287288289297337
Results 5,721 to 5,740 of 6871
  1. #5721
    Jun 2007
    43
    Re: Hoss's G0704
    Hoss, have you had any issue with your treadmill motor cycling? The one I've put in place comes up to speed pretty good, but shortly after it slows way down, and speeds back up. If I put any kind of side load on it, it goes away. Just wondering what others have down to stop this.
  2. #5722
    Re: Hoss's G0704
    No, hadn't had anything like that with the treadmill motor, what controller are you using?
    Hoss
  3. #5723
    Jun 2007
    43
    Re: Hoss's G0704
    I just installed a kbmm-125 controller.
  4. #5724
    Re: Hoss's G0704
    That's what I have, haven't had any trouble with it, how are the brushes in the motor?
    Hoss
  5. #5725
    Aug 2010
    23
    Re: Hoss's G0704
    Sounds like the IR and/or CL trim pot needs to be adjusted. Make sure you have the correct HP resistor installed and follow the manual's instructions for calibration. Fully cranking the accel pot can sometimes cause cogging as well.
  6. #5726
    Jun 2007
    43
    Re: Hoss's G0704
    Looks like the IR was it, I turned it down a little and everything smoothed out! Thanks CodeRage.
  7. #5727
    Feb 2014
    197
    Re: Hoss's G0704
    So I bought Hoss's plans for the CNC conversion of the G0704. I have read some are using a tapered bearing for the bottom bearing on the Z axis to give better lateral support. I am using AC bearings for the top and bottom bearing on the Z axis. I'm I doing this wrong? Is there a better option?
  8. #5728
    Re: Hoss's G0704
    Don't know who would be using two types of bearings but two AC bearings are proper, there is no need for large lateral support especially if you use direct drive.
    The lower bearing doesn't provide much in the way of support anyway as the weight is hanging off the top bearing, the stock mill doesn't even have a lower bearing.
    Two AC's are needed for CNC for backlash mitigation.
    Hoss
  9. #5729
    Re: Hoss's G0704
    Finished up the rear y axis with the new mounts, very pleased.
    A little testing then I can move on to other projects.
    I still need to make the stair lift to get access to the basement again among others, I cut up a $300 ladder for that project.
    Hoss
  10. #5730
    Aug 2010
    630
    Re: Hoss's G0704
    Quote Originally Posted by hoss2006 View Post
    Hoss
    Exactly why did you cut up a $300 ladder.. and what did you use it for ?
    Inner Vision Development Corp. - http://www.ivdc.com
    Website Design & Development. Shopping Carts, SEO and more!
  11. #5731
    Apr 2005
    1268
    Re: Hoss's G0704
    Hoss;
    What do you use under your stock to boost the material up so that the table is protected? I'm getting ready to build up a tool plate for my Torus and want to raise it slightly to avoid cutting into the table.
    Bill
    billyjack
    Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
  12. #5732
    Re: Hoss's G0704
    Quote Originally Posted by Connor View Post
    I didn't use it yet but it'll be for a modified portable roof shingle lift (look it up on youtube) but will have a seat and use a power hoist to move up and down the stairs.
    Hoss
  13. #5733
    Re: Hoss's G0704
    Quote Originally Posted by bill south View Post
    Hoss;
    Bill
    Lots of things, spacers cut from thick ally tubing, ally bar stock, 1/4" plastic sheet, the leftovers from cutting out parts from ally plate deburred of course, ally square stock lengths and so on, this is all just temporary sacrificial pieces per job.
    If you are raising a tooling plate I'd attach permanent square stock to the underside or at least permanent feet.
    Hoss
  14. #5734
    Apr 2005
    1268
    Re: Hoss's G0704
    Thanks Hoss;
    I'm thinking permanent feet at the ends and in the middle edges. Do you think 32 inches of 3/4 aluminum, eight inches wide should be rigid enough with just the ends and middle supported? Inquiring minds want to know. Or at least I'd like an opinion. Many thanks in advance.
    Bill
    billyjack
  15. #5735
    Re: Hoss's G0704
    Something that long I'd probably go 1 inch thick and/or use 4 feet spaced evenly along the length.
    Hoss
  16. #5736
    Apr 2007
    17
    Re: Hoss's G0704
    That's about what I was seeing too. Now that I have several hours on it I'll have to see what it is. The last thing I did was carve out a small 2" mold out of wax using a .002" bit and was not able to see an evidence of backlash. I've been quite happy with the double nut performance.
  17. #5737
    Re: Hoss's G0704
    Yeah they are definitely worth the few extra bucks over the single nuts.
    Hoss
  18. #5738
    Apr 2007
    17
    Re: Hoss's G0704
    Hoss
    There's no point in getting the single nuts at this point. The best part is I used the plans I got from you a year ago and I only needed to adjust the length of the stepper standoffs. They slid right in without any loss of travel or additional modifications, with nothing more than basic hand tools and a dremel. Adding a 1.5kw spindle next.
  19. #5739
    Aug 2010
    630
    Re: Hoss's G0704
    Hoss
    I asked before.. not sure I got a clear response. What, if any loss do you have with the Y-Axis? I want to order my double nut screws and was planning on doing the 2" rear extension with a front mount stepper. So, My questions are as follows.
    A) Any issue mounting the Front-Mount extended version of the Y-Axis screw WITHOUT the extension.
    B) What can we expect our travel to be. (With the 2" extension added)
    C) What modifications were needed in the original 2" Extension?
    D) Is the 2" extension for the spindle needed ?
    My reasons for asking all this is.. I'm not planning on doing the 2" extension right away.. but, I want to go ahead and do everything for it short of adding the extension to the back of the base, and make the tombstone 2" extension for the spindle. (I.E. Add the longer ballscrew)
    Thanks, Billy
  20. #5740
    Aug 2010
    630
    Re: Hoss's G0704
    Dupe
  1. Hoss's G0704
    By hoss2006 in forum Benchtop Machines
    Last Post: 03-25-2016, 12:48 AM
  2. Another G0704 conversion - Hoss's plans - LinuxCNC control
    By otto_pjm in forum Benchtop Machines
    Last Post: 11-14-2013, 06:26 PM
  3. G0704 Y axis Thrust Bearing Block and Stepper mount from Hoss Plans
    By LLDesigns in forum RFQ (Request for Quote)
    Last Post: 12-12-2012, 02:49 AM
  4. RFQ A few parts from Hoss G0704 Plans
    Last Post: 10-21-2011, 09:13 PM
  5. Hoss does it again!
    By tooManyHobbies in forum Benchtop Machines
    Last Post: 11-01-2008, 06:29 AM
