586,584 active members*
2,980 visitors online*
    Jun 2005
    Probing - Mazak Fusion
    Ok...I'm not the CNC guy - but I am the computer guy and general tinkerer...
    WARNING: Our scenario may not be DIY enough for here - I don't know!
    We've got a Mazak VCN-510C (with Fusion control) but did not get any probing capability with the machine.
    Ebay's got all kinds of Renishaw machine probes for dirt cheap regularly...that's great...but I don't have the foggiest idea on what else I need.
    I'd love for our operator to actually be able to measure parts in the fixture via probing. Obviously I could call Mazak and they'd be happy to turnkey it for me but I suspect there is a less expensive route.
    Suppose I buy a probe from Ebay...what else should I get?..what else do I need?
    Thanks!
    24223
    Usually the probe is used with G31, the output of the probe goes to a high speed input labeled skip-input, you will also need measuring routines, renishaw have them for different controls, but they charge you for them. Unless you can write them yourself.
    Al.
  1. Need help with Mazak Slant Turn 15 Univ. / Mazatrol T1'
    By Haaatschi in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-11-2021, 01:33 PM
  2. Mazak 8G M/C,mazatrol eia-t, z axis stuck
    By imwllc in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-07-2009, 04:48 PM
  3. Mazak Rotary Turret Switch reBuild
    By Al_The_Man in forum News Announcements
    Last Post: 04-11-2007, 04:21 PM
  4. Mazak C axis programming
    By dpinson in forum Uncategorised MetalWorking Machines
    Last Post: 07-02-2005, 09:06 PM
  5. Mazak L Alarm
    By SFA in forum DNC Problems and Solutions
    Last Post: 05-26-2005, 06:52 AM
