586,728 active members*
3,291 visitors online*
Results 1 to 20 of 28
    Jan 2010
    321
    mill motor issues. help please
    howdy all.
    have been lurking around here for a while now just reading and learning.
    i recently brourght myself a Ostmac (king rich KRV2000) knee mill and a chinese lathe. both second hand and 3 phase. the plan was to use 2 vacon vp10 single phase to 3 phase invertors to run these machines on 1 phase power,
    so far all going great, i have the lathe converted and running great but the mill is proving to be a little harder. i have sorted all the electrics out have have the motor running off the invertor but that is were the problem starts.
    both the mill and lathe have 3hp motors on them. the mill motor is a modified king rich motor. it was a star winding only motor so had to have the delta winding dug out and brought to the terminal box.
    the lathe motor is a brand new 3hp 3phase motor that i wired in delta. when running the lathe at full speed (1800rpm) the motor draws 5.5odd amps runs a treat. when i run the mill it draws 3odd amps and when i wind up the variable speed pullies the motor drops alot in rpm so much so it would stall if i keep winding the handle. i have watched the amp meter on the invertor and it stays at the 3 amps only even when loaded. (the motor is rated at 8 amps and the drive at 9.6 amps)
    keep in mind the invertor is the exact same invertor i only have 1 invertor at this stage so it does work well with the lathe motor but doesn;t work on the mill motor.
    i have even hooked the motor wires from the mill motor to the lathe so i am using the mill electrics but powering the lathe motor and all seems great.
    i have spoken to a guy that has done this exact conversion and has had great sucess except he has used a different brand invertor but other than that the conversions are identical.
    i spoke to the guy that did my mill motor mods and he said the motor is fine. i spoke to the invertor people and they say the motor is at fault.
    i am now banging my head agaist a wall trying to nut this one out. for some reason the motor doesn't want to run on the invertor. if it was an easy job to install a new universal fit motor i would but it will mean making adapter plates and shafts and i want to avoid this if i can.
    anyone got any ideas? before i throw a match to the lot.
    cheers guys
    dean
    Mar 2009
    1982
    It's normal. Motors are not identical. You can find some difference easy.
    1. check resistance of insulation at (800 ... 1500)V
    2. check inductance of windings
    and once again. Are winding connections the same? Both star?
    Jan 2010
    321
    both motor windings seem the same connections. the motor guy connected the windings on the motor i am having trouble with in 3 pairs. so there is 2 winding connections coming off each terminal.
    the lathe motor seems the same. i had to change the 'bridges' from joining only 3 terminals together to joining 6 terminals in 3 pairs.
    how do i measure the resistance of the insulation of the inductance of the windings.
    is there something in the above results that i should be looking for.
    thanks again
    Jun 2010
    4256
    Measure!
    Before coming to any decisions, measure the output of the inverter when under load. I suspect that it just can't handle the current, and the voltage drops.
    Best solution: see what it would cost to get 3-phase brought in to your shop.
    Cheers
    Jan 2010
    321
    Quote Originally Posted by RCaffin View Post
    Cheers
    3 phase is not an option as i am only in this place for a year or so.
    the thing is this invertor works great on my other 3hp motor (lathe) so i don't see why there is such a huge difference in the performance between the 2 different 3hp motors.
    with no load on the motor it draws 3 amps with the any type of load it still draws 3 amps. i would understand if the amps sky rocketed breifly then dropped down to 3amps but this does not happen.
    i will try to measure the current when i get my new invertor. the invertor i have is now on the mill
    thanks
    dean
    Jun 2010
    4256
    Quote Originally Posted by Deano7/11 View Post
    Well, there are motors ... and motors.
    There may be an internal electronic limit in the inverter, set at 3 A. If so, and it would surprise me if it were NOT so, you won't see any surge.
    Without measurements we know very little.
    Cheers
    Jan 2010
    321
    Cheers
    the current limit in the invertor is set to 12.5a
    the motor current is set to 8 amps.
    i am happy to measure whatever you think i should but i need to no how to measure these things. i have a multimeter if that helps
    Jun 2010
    4256
    Hum, yeah, well, that should be enough current!
    I suggest measuring the AC voltage (with care) on all three phases when running both motors. If the voltages are all the same, then I am puzzled.
    Hard to debug things over the internet!
    Cheers
    24223
    It appears to me you have something mis-connected in the motor, see if you can get it tested on straight three phase and put a load on it.
    Did you bring all 6 ends out and connect in delta?
    If you have below normal current on load then with your VFD settings then I would say it is something motor related.
    What is the original star connected voltage rating?
    Al.
    15362
    RCaffin
    You can't measure the output of the inverter unless you have an oscilloscope, because you do not get true AC out of a VFD, so it will not read on a multimeter correctly
    I think you have a wiring problem, or a bad motor, most likely just the wiring of the motor
    Deano7/11 can you do some photos of the inverter wiring & the motor wiring
    Mactec54
    Jan 2010
    321
    thanks for the replies guys.
    i will get some pics of the connections in the next day or so. my camera is at my gf house.
    the invertor is a brand new unit. it is currently fitted to the lathe an is working a treat on a new 3hp motor draws 5.6a when the lathe is in high gear (1800rpm).
    i guess i could get the motor tested by someone else as the guy that did the mods to the windings for me wasn't really intrested in testing it cause he is certin it is not the problem. i can send it across town to another guy that has done this mod with great sucess to other king rich motors
    Mar 2009
    1982
    simple. first You take all ends of windings separate. 1.1 ... 1.2, 2.1 ... 2.2, 3.1 ... 3.2 like this. Next you measure resistance of each winding @(1 ... 15)kHz. Note - DC operated measurement doesn't works. You need to feed AC.
    Third, You connect two windings in series like 1.1 winding 1.2 connection 2.1 winding 2.2 and take measurement between 1.1 and 2.2. If the resistance is not double, change connection like 1.1 winding 1.2 connection 2.2 winding 2.1. and check the resistance (between 1.1 and 2.1) now. Correct connection is when Your resistance is rising. Mark the ends of windings and then You will have possibility of correct wiring.
    If this doesn't helps, then You need special high voltage device to measure resistance of insulation.
    Jan 2010
    321
    Quote Originally Posted by Algirdas View Post
    wow that is dutch to me. i will take some pics and post them up and i will get you to talk me through the above process if you don't mind
    thanks
    dean
    15362
    Deano7/11
    I would do what you have said,take the motor to another motor shop, & have them run it on 3PH & put the wring on it correct for your set up, I guess you are putting 230/240 single phase in, he may have it wired for 400/415v which is your normal for your 3phase it needs to be wired for 230/240 3phase to work correct
    Is your inverter 230/240v single phase in & 230/240v 3ph out
    Mactec54
    Jan 2010
    321
    yes i suspect the only reason that this motor does not run properly is if the motor guy has matched the 3 pairs of wires wrong.
    i will take some pics tonight i now have my camera.
    i told the guy exactly what i wanted to do with the motor and that was to run the motor off a 230v 3ph output invertor so i assumed he did it this way. he has stamped the motor with 230v on the nameplate as well so pretty sure he understood exactly what i wanted.
    a 2nd opinion would be in order i think but if i can understand Algirdas' post i may be able to check myself
    Jan 2010
    321
    ok guys i have got my camera and mullti meter and taken some pics and measurements.
    when i measure resistance with the multimenter set to 200 the new universal fit 3ph 3phase motor wired in delta measures 1.6. the mill motor measureing the same way measures 3.1. i have been measureing i think between phases. if that shonds right.
    her is some pics of the motor and invertor connections.
    Jan 2010
    321
    cant upload pics for some reason. the attachment manager is not getting a response from cnczone. will try again another time
    Jan 2010
    321
    this is the terminal box on my lathe. it is a universal 3hp motor that is connected in delta measures 1.6 resistance between the terminals
    Jan 2010
    321
    this is the wiring of the invertor
    Jan 2010
    321
    this is the terminal box of the mill motor.
    measures 3.1 resistance berween the 3 terminals
  1. Issues with my mill
    By Hack in forum Uncategorised MetalWorking Machines
    Last Post: 11-21-2009, 07:25 PM
  2. Motor voltage issues
    By Greg King in forum DIY CNC Router Table Machines
    Last Post: 10-08-2009, 04:07 AM
  3. 5.25 floppy motor issues
    By KsiR in forum CNC Machine Related Electronics
    Last Post: 05-10-2009, 11:33 AM
  4. Motor speed issues
    By rich_cree in forum Gecko Drives
    Last Post: 02-21-2009, 02:57 AM
  5. More Motor Issues
    By pzzamakr1980 in forum Benchtop Machines
    Last Post: 10-19-2007, 10:35 AM
