586,655 active members*
2,985 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Waterjet General Topics > Has anyone bought from Changzhou Longs-Motor?
Page 2 of 2 12
Results 21 to 30 of 30
  1. #21
    Sep 2005
    1195
    Re: Has anyone bought from Changzhou Longs-Motor?
    Hi Mary,
    I know this post has been a long time. I just want to ask you : changzhou-longs-motor is the same as changzhou-wantai-motor ? The product is almost the same, like a twin product.
    Why don't you put the wiring in here ? Thanks.
  2. #22
    Dec 2015
    12
    Hi does anyone know if the longs motor kits work with linexcnc? I cant seem to get mine to work with mach3 so i. Thinking about trying linexcnc... thanks
  3. #23
    Sep 2005
    1195
    Mary,
    Can you post wiring diagram on here ... ?
  4. #24
    May 2015
    686
    Yes, I am using Longs motor with LinuxCNC. I like their DM542A stepper driver and use 25x microstepping with no problems. I am using a Mesa 7i76e ethernet board so don't use their breakout board but I have tested it and confirmed it works with LinuxCNC.
    Rod Webster
    www.vehiclemods.net.au
  5. #25
    Sep 2005
    1195
    Hi Rod,
    How difficult to wire linux cnc? How expensive ? Are they more powerful than mach3 or uccnc ?
  6. #26
    May 2015
    686
    Quote Originally Posted by asuratman View Post
    Hi Rod,
    I think there is a reason why Tormach and CandCNC have migrated to LinuxCNC. Its better, its open source and its free!
    The wiring is probably no different. As you can have a lot more inputs with some hardware, you can wire in seperate limit switches and a home switch on each axis so there might be more wiring to do but you will have a better machine for it.. For a simple lathe or mill, there is a config program that should do 90% or more for you. I've edited the config files by hand for my plasma build.
    Rod Webster
  7. #27
    Hi Asuratman,
    I am stepper motor sales at JUGETEK, We are factory for this, any question about wiring and dimension, you can send us [email protected] .
  8. #28
    I have those same motors I just purchased from longs for two of my mills and I just heard back from longs after inquiring about the motor mounting and they responded that these motors are not designed to be used with ballscrews due to the high accuracy of ballscrews the steppers will not perform well. Have you actually ran these on your mill cutting anything yet?
    Quote Originally Posted by rodw View Post
  9. #29
    May 2015
    686
    Quote Originally Posted by Uguessedit View Post
    I'm only using their stepper drivers to drive my plasma cutter which is a low torque situation. I don't expect that their motors would be any better or worse than those I purchased from steppers on line. I do have a friend with a Seig SX3 CNC mill and a home made CNC lathe who uses the same drivers and he has no accuracy issues.
    Rod Webster
  10. #30
    Dec 2009
    36
    I just bought this kit off of amazon, with no wiring diagram. I can figure out the wiring but can any one tell me which dip switch needs to be pushed, and the wiring diagram just in case. thank you
Page 2 of 2 12
  1. Longs Motor NEMA 34 1600 oz in kit. Drivers Dead?
    By Streetslab in forum Stepper Motors / Drives
    Last Post: 01-06-2017, 08:36 PM
  2. Changzhou Wantai Electrical Appliance Co. Ltd
    By wantmotor201204 in forum News Announcements
    Last Post: 09-15-2012, 07:04 AM
  3. Help with 878oz Kit from Longs Motor?
    By allengambrell in forum Stepper Motors / Drives
    Last Post: 03-27-2012, 04:16 AM
  4. Bought a brushless servo motor, now what?
    By draemr in forum Servo Motors / Drives
    Last Post: 07-15-2008, 01:01 AM
