Hi all,
Firstly, thank you all for your help on my birch plywood post, your help has been invaluable.
My next question is...
If you had a choice between a 50Watt red type (?) glass laser and a 70Watt RF Coherent laser to go in a machine that you will be using to cut 4mm birch plywood, what would be the better option?
(Lens options and air assist will be used included for both options)
Thanks in advance !!
