587,035 active members*
3,282 visitors online*
    Oct 2007
    1025
    mach3 parallel port or USB?
    will mach 3 work with usb,noticed when i downloaded it that there was no mention of usb
    Only with an external motion device with a Mach3 plugin. Either the KFLOP or Kmotion from http://www.dynomotion.com/ or the Smoothstepper from www.warp9td.com
    Normal operation of Mach3 without additional hardware is parallel port only.
    Oct 2007
    1025
    flashcut
    the plasma machine is run right now via flashcut and i would like to try mach 3,but the system is run by usb and i wasn't sure if mach3 has a usb input
    You can't use a Flashcut controller with Mach3, if that's what you're asking.
    Oct 2007
    1025
    ok
    Thats exactly what i am asking ,we're not happy with flashcut so it hought we would try mach3 but you have corrected that ,saves me wasting my time .Thanks a lot .
    The only way mach3 is going to run this machine is to bypass the flashcut electronics and wire the 2 drives to a breakout board then to parallel port which is a lot of work.Thanks again
    stan
  1. How to add a second parallel port in mach3
    By waleed alhadidi in forum Mach Software (ArtSoft software)
    Last Post: 05-30-2010, 03:45 AM
  2. Mach3 on Laptop without Parallel Port
    By Deviant in forum Mach Software (ArtSoft software)
    Last Post: 09-01-2009, 01:34 AM
  3. Mach3 Not Working At All With Parallel PCI Port
    By Brenck in forum Mach Software (ArtSoft software)
    Last Post: 07-15-2009, 01:43 AM
  4. parallel port or parallel universe
    By bruno34 in forum Taig Mills / Lathes
    Last Post: 04-15-2009, 04:58 PM
  5. Mach3 and Parallel port
    By Me2 in forum Mach Software (ArtSoft software)
    Last Post: 01-28-2007, 11:38 PM
