587,003 active members*
3,007 visitors online*
    Jan 2010
    24
    Heidenhain control?
    We have a Tos Varnsdorf bridge mill with Heidenhain control (fun stuff). I'm trying to figure out the best way to program the following:
    (fanuc control)
    *90 DEGREE COUNTER SINK TOOL*
    G00X16.7875Y0.0S450M03
    G43H55Z8.0M08
    G98G82Z6.43R6.8P200F2.3
    X16.7236Y1.4631Z6.477R6.587
    X16.5325Y2.9151Z6.43
    X15.7751Y5.7417
    X15.2146Y7.0947Z6.45
    X14.5384Y8.3938Z6.43
    X12.142Y9.4424
    X9.6289Y13.7515Z6.45
    X14.5384Y-8.3938Z6.43
    X15.7751Y-5.7417
    X16.7236Y-1.4631Z6.45
    G80M9
    To make the above program for the heidenhain control, the program will be...???
    N75 W-20M91
    N80 X+16.7875Y0.Z+10.M03
    N85 G83 P01 -0.25 P02 -.37 P03 -.37 P04 .2 P05 20.3
    N90 Z+8.M8
    N95 Z+7.05 M99
    Not sure how to simply alter the R plane or Z plane in the heidenhain control. Anyone help?
    Nov 2006
    925
    What model of Heidenhain is it?
    Have you downloaded the free programming manual for your control from the Heidenhain website?
    Quote Originally Posted by rylanrouge View Post
    N75 W-20M91
    N90 Z+8.M8
    N95 Z+7.05 M99
    So with the HDH G83 cycle N95 Z+7.05 is the start height (R plane), G83 P01 is the incremental distance from the start height to the work piece surface and G83 P02 is the incremental drill depth from the work piece surface. The line with M99 calls the drill cycle.
    Here is where you have to be careful when you change the Z start point you also have to change the G83 P01 value. This is because everything in the G83 cycle is incremental.
    So for example if you change Z+7.05 to Z+10.05 you'll have to change P01 from -0.25 to -3.25 otherwise your hole will be 3" to short.
    This is an old style cycle but still good and useful.
    Also G83 is the same as HDH clear-code Cycle 1
  1. Heidenhain tnc 2500 Control
    By Booda in forum Bridgeport / Hardinge Mills
    Last Post: 08-05-2010, 02:02 AM
  2. Help with Heidenhain 4110 Control
    By Eggo von Eggo in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-26-2007, 10:47 PM
  3. Compact CNC Control from HEIDENHAIN
    By stoogeweb in forum News Announcements
    Last Post: 07-09-2007, 03:34 AM
  4. Heidenhain TNC 155 Control Question
    By riggsmachine in forum Bridgeport / Hardinge Mills
    Last Post: 04-22-2006, 11:38 PM
  5. Heidenhain 530 Control
    By capitalv in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-04-2005, 05:16 PM
