586,770 active members*
8,967 visitors online*
View Poll Results: Where did you purchase your laser from?
Voters
31. You may not vote on this poll
  • Legacy Lasers
    5 16.13%
  • Epilog
    4 12.90%
  • WK Laser
    14 45.16%
  • Golden Laser
    0 0%
  • Logilase
    0 0%
  • Redsail
    8 25.81%
Page 3 of 6 12345
Results 41 to 60 of 111
  1. #41
    Feb 2005
    124
    That counts for me too. In February I bought the HX6090 from HXLaser but because of a lack of space we had to put it into storage. When I finally found a garage to work in, the door was only about 0.7 meter wide and we had to drag the whole machine a lot of meters. This meant that we had to disassemble the WHOLE machine(all doors, Z-direction construction, electronics, etc) and assemble it later again. Luckily I'm instrumentmaker in my daily profession so it wasn't that hard but still a LOT of work.
    Made my first holes monday, was very cool to finally see the laser cutting some cardboard. I'm going back to the garage in 5 minutes to do some more cuts, the thought already makes me nervous :P
  2. #42
    Aug 2007
    422
    Congrats on getting your laser fired up. I have a ton of projects already lines up for my laser and after I get the machine all organized I will be starting the trial and error part of the learning curve. how many watts is your 6090?
    Necessity is the mother of all invention (unknown)
    My club home page www.lhmac.org
  3. #43
    Feb 2005
    124
    It has a 60Watt tube. Yesterday it was only possible to cut through cardboard at the 100% setting. Something had to be wrong so I finally tested if the laser bundle that hits the focus lens was aligned well: it was way out. Now I can cut cardboard at speed 400 and 25% power. Very cool
    I tested some dxf from the download section and works nice. The supplied program 'lasercut 5.1' is not even that bad...
    Make sure your aligning is right(nice round spot) and take your time. You will love it when it works(at least I do).
  4. #44
    Aug 2007
    422
    Luckily for me I had Ray there to set the whole laser up and show me how to do everything. The lasercut software does seem pretty easy to use, i just need more practice. I cut out some depth gauges last night and they look awsome. I love the machine so far, I am just afraid of doing something stupid and damaging the machine. once the sticker shock wears off I'll be going full tilt.
  5. #45
    Dec 2008
    1258
    Just avoid PVC and you can't go far wrong.
    Soon you'll be lasering EVERYTHING!
    Zax.
  6. #46
    Aug 2007
    422
    Yeah I was made aware not to use PVC. I also heard not to use plexiglass or lexan. I have a bunch of scraps but I don't know what they are. is there a way to tell??
  7. #47
    Feb 2005
    124
    Quote Originally Posted by rcpilot82 View Post
    Plexiglass(acrylic) cuts beautiful but lexan is a problem indeed. If the material is clear and you have a bit of experience with plastics, you will find that lexan doesn't scratch as easy as acrylic glass and is much harder. Not sure about cutting but I've read that when you lasercut it, the etches look bad.
    I'm testing a lot of materials myself and try to find the optimal speed and power but that takes some time. Also had my first burning cardboard yesterday because I set the laser to 80% output and low speed, oops
  8. #48
    Feb 2005
    469
    Quote Originally Posted by zax15uk View Post
    Zax.
    Yep.... it's true! lol
  9. #49
    Dec 2008
    1258
    rcpilot82,
    As fantasy2 already said, Plexiglas is a brand of Acrylic which engraves and cuts very well and is probably the most laser friendly plastic.
    Lexan is a brand name of polycarbonate and although laser safe it is more difficult to get good results due to melting. Some of the plastic ply materials use it since it's more flexible and when thin can be engraved off fairly easily.
    There are a couple of ways to tell the difference, putting a flame to a corner or doing a scratch/chip test. The laser results will probably tell you too
    Most materials won't cause any ill effects, just watch for the Chlorine. If you do create a fire in the laser by cutting cardboard or similar, just shut down the beam and it will usually extinguish itself.
    Zax.
  10. #50
    Dec 2008
    1258
    Quote Originally Posted by SkipW View Post
    Now don't go giving him ideas!
    Zax.
  11. #51
    Aug 2007
    422
    Zax.
    HA, I already got a ton of ideas. I am getting the hang of the machine more and more each day. This weekend I am going to do some tests and figure out what power/speeds I need for cutting Balsa and depron. those will be my two most cut materials.
  12. #52
    Feb 2005
    124
    That's a toilet seat? Nice!!
    I wonder what your settings will be. I tried to cut cardboard(harder than depron) at 30% power and 200 speed. This goes well but it should be able to cut at a much higher speed(like 400) but for some reason the laser has some kind of delay that, when it starts cutting, it's always too late with the laser and it misses some material at the start of the cutline.. I wonder if there is any setting that fixes this issue?
  13. #53
    Aug 2007
    422
    I have been looking for baseline info for cutting balsa and depron but can't find any. actually, I can't find any baseline info period. I was told that for depron you need alot of air assist flow to keep the foam from melting. I guess i just need to find the time to sit down and really play with it. I am documenting any settings I get when I am happy with them for reference.
  14. #54
    It's really nice to read the exploits of rcpilot and his new toy.
    (I bet he eats his meals in the workshop now)
    Tweakie.
    CNC is only limited by our imagination.
  15. #55
    Jul 2008
    776
    Not today Today is Friday so he drink beer :cheers:
  16. #56
    Aug 2007
    422
    Haha, I'm not that bad...yet.. I eat at least dinner upstairs with the family so i can spend some time with em. I am starting to relize the potental of the laser as I try it on new things and find out that "yep it can do that to". This weekend hopefully I will make alot of progress on the learning aspects and be able to start and make some real parts instead of "test" parts.
  17. #57
    Aug 2007
    422
    Quote Originally Posted by Litografa View Post
    LOL, no beer for me. I have a meeting after work and a ton of preperation work for a club event to do tonight. Maybe a captin n coke later though.:cheers:
  18. #58
    Aug 2007
    422
    Couple more pics
    here are a few more pics of the Laser and the height gauges I made. better quality than the cell pics before.
    Attached Thumbnails Attached Thumbnails IMG_8180.JPG   IMG_8197.JPG   IMG_8194.JPG   IMG_8195.JPG
  19. #59
    Jun 2008
    69
    Hi rcpilot82,
    Congratulations about your new laser - great machine - but causes sleepless nights to you ( when thinking what new I'm going to try tomorrow )
    Balsa cuts beatufully, depron melts very easy -try to find settings with lowest possible power and highest possible speed to avoid melting ( help's also to keep your tube's lifetime longer ).
    Anyway, enjoy and hope to see some of your future works !
    Best regards
    - Hannu
  20. #60
    Aug 2007
    422
    Yeah, the sleepless nights are definatly getting old.LOL, Hopefully I will have enough time this weekend to do an actual project and post some pics.
Page 3 of 6 12345
  1. Laser purchase
    By Gary123xyz in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-29-2015, 02:20 AM
  2. Recommendation for New Laser Purchase
    By jmusser15 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-13-2012, 03:10 AM
  3. Save $300 on your laser purchase!
    By fslaserboy in forum Engraving Machines
    Last Post: 07-23-2011, 02:09 AM
  4. Laser purchase thoughts
    By pitbldr in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-12-2010, 08:27 AM
  5. Laser engraver purchase or DIY
    By WillyInAus in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-27-2009, 01:05 AM
