586,909 active members*
3,541 visitors online*
    Jun 2010
    Tips on laser cutting soft materials
    Hi there,
    just discovered this forum as I am a newbie in laser cutting etc.
    I have a Versalaser 3.50 and trying to cut a thin plastic material (plastic stickers in fact).
    My problem is that mid-way through the cutting, the material becomes curved and interferes with the head, causing the process to stop.
    I have attached the plastic material to the bottom plate with double-sided tape to stop it from curving but I guess that might not be the best solution.
    Anyone have any ideas on this?
    Jim.
    Hi Jim,
    Not that it's much help but plastic material curves because it is getting hotter on one side than it does on the other or alternately is cooling down quicker on one side than it is on the other. It is probably quite easy to adjust the volume of the air assist for the top surface but keeping it cool on the underneath is an issue which I have not yet found a suitable way to resolve. (when cutting acrylic it sometimes bends upwards slightly, it never bends downwards). I think re-design of the cutting bed may be the only answer, perhaps your question will through some light on a solution.
    Tweakie.
    CNC is only limited by our imagination.
    Jul 2008
    776
    Hello,
    Look here for POSSIBLE solution
    http://www.litografa.lt/index.php?aid=357
    Hi Litografa,
    I have a vacuum table which is just fine for engraving work but it is no use for cutting acrylics on.
    The main problem encountered when cutting right through is reflections from the table damaging the back edges of the work.
    It was a good thought though.
    Tweakie.
    Jul 2008
    776
    OK, look here
    http://www.litografa.lt/index.php?aid=360
    you set necessary quantity of pins in points where will be NO CUTTING. Put material on pins and with hand made caps FIX material on pins. Caps are usually made from plastic and you just slightly pin (put on) this caps to the top of table metal pins to keep material in tension.
    But really I think vacuum table should work for this job as Jim mentioned that materials is THIN, so really there will be NO back side mark during cutting
  1. HUGE mill for foam, mdf and other soft materials?
    By xarvox in forum CNC Machining Centers
    Last Post: 12-04-2011, 02:50 AM
  2. Bill of Materials tips help pls
    By Rich05 in forum Solidworks
    Last Post: 08-11-2008, 06:27 AM
  3. What to use when cutting thin materials ?
    By twocik in forum Benchtop Machines
    Last Post: 04-07-2008, 09:49 PM
  4. laser cutting tough, light, flexible sheet materials?
    By vacpress in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-12-2008, 02:36 AM
  5. Dumpster/Curb Scavenging tips-- free parts/materials.
    By danreetz in forum Community Club House
    Last Post: 05-05-2007, 01:20 PM
