586,829 active members*
3,346 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Toolchanger problem with Fanuc 10T
    Jun 2010
    Angry Toolchanger problem with Fanuc 10T
    I run a Victor CNC TNS-3H Lathe with Fanuc 10T. Normally it works just fine, but now when i do a toolchange in a program or MDI, both X and Z start to move at the same time the turret indexes. It moves in rapid and if i don't stop/reset, it would run into the chuck.
    The work zero and tool offsets are ok...
    Any ideas what the problem could be?
    2932
    Is it possible that someone changed parameters?
    #6001 bit 2 = 0 applies the geometry offset by shifting the work coordinate system.
    #6001 bit 2 = 1 applies the geometry offset by moving the tool.
    bit 3 is the same for the tool wear offset.
    Jun 2010
    No, it's only me using the machine. I restarted the machine a few times and after a few hours it was working again, i guess its just old :P
    I'll check that bit if it happens again! Thanx
  1. toolchanger on MB3 VMC
    By underdog in forum HURCO
    Last Post: 03-21-2009, 10:42 PM
  2. diy toolchanger???
    By marcerasmus in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 10-08-2007, 05:24 AM
  3. cnc DIY toolchanger???
    By marcerasmus in forum CNC Tooling
    Last Post: 10-07-2007, 10:30 PM
  4. Fanuc 0i-MC and ARM type toolchanger
    By ddanutz in forum Fanuc
    Last Post: 08-27-2007, 10:57 PM
