587,511 active members*
2,972 visitors online*
    Jan 2006
    628
    Colored phenolic? Thin corian sheets?
    I have a customer who would like some model parts cut out of a colored sheet material. Bright, primary colors - red, blue, yellow, etc. The thicknesses are 1/8" and 1/4".
    We've been using baltic birch and then painting it, but would like to try some solid materials. The material should be reasonably stiff, stable and not brittle, but doesn't need any great strength. Ease of machining is a plus. Reasonably priced.
    Perhaps a colored acrylic or polycarbonate would work.
    Phenolic (micarta) might be an option, but tough on tools.
    Corian machines nicely and glues pretty easily.
    HDPE, UHMW not so great in terms of gluing.
    Colored MDF not strong enough, maybe tempered hard board?
    Mix and matching is a possibility, so doesn't have to be the same for both thicknesses. Anybody have a source for these materials in thin (colorful) sheets, or could you suggest an alternative?
    Thanks very much,
    Steve
    Apr 2010
    A really great website that has Hot (bright red) and Graphic Blue is http://solidsurface.com . There really aren't many manufacturers that make bright solid colors. I hope this helps!
    Jan 2006
    628
    Thanks! The site looks like it might do the trick.
    Steve
    Apr 2004
    31
    colored plexiglas MC
    I have 4-5 sheets of red,it is not bright,but red,Plexiglas MC. do a search on the net, for more info..size is 10''x28''~ thickness .116, also have white,in the same size approx, some cosmetic scratches,and useful material. If you want more info.. e-mail bossproduction at comcast dot net. can give a photo, if interested.
  1. Phenolic advice
    By DrStein99 in forum Composites, Exotic Metals etc
    Last Post: 04-08-2012, 02:49 AM
  2. Lasers for Cutting Fiberglass/Phenolic
    By psiwaterjet in forum Waterjet General Topics
    Last Post: 11-26-2007, 05:22 PM
  3. SFPM for dielectric canvas phenolic ??
    By Rekd in forum DNC Problems and Solutions
    Last Post: 08-06-2003, 07:21 AM
