587,220 active members*
2,746 visitors online*
Hybrid View
    Nov 2005
    57
    Mazak Mazatrol M-2 Rapid
    Hello CNC people.
    On the mazatrol M-2 control It is 2 buttons for more feed and
    less feed 0 to 200 percent.
    To left off more feed button is a button looking like a rapid
    movement (long wave with 2 arrows pointing down.)
    Quest. Can somebody on the site tell function off that button?
    Sve0019
    Nov 2006
    925
    The button is called "Rapid reduce"
    According to the manual it`s a key to slow the feed speed from the reference speed.
    A decelerating speed is to be set in the parameters.
    Please don`t ask me what all that means.
    Mark.
    Mar 2010
    It cut's the rapid ''go" moves in 1/2 .
    Apr 2010
    are you talking about your spindle jog buttons? If your are when you go into manual mode if your spindle has two gears you need to pick one. After you select a gear you can press spindle start and you can jog the spindle rpm up and down.
  1. Mazak M-4 Mazatrol T2 and mazatrol Cam T2 operating manual in english
    By tuanpq in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-09-2021, 04:06 PM
  2. Mazatrol T1 - Mazak
    By valvulin in forum Spanish
    Last Post: 10-31-2008, 10:17 PM
  3. Mazak, Mazatrol T1
    Last Post: 10-10-2008, 06:17 PM
  4. mazak(mazatrol-m1)
    By mohd khalid in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-06-2006, 04:47 PM
  5. Mazak H15 with Mazatrol M2
    By Steve_rb in forum DNC Problems and Solutions
    Last Post: 03-19-2004, 01:27 PM
