586,553 active members*
3,418 visitors online*
Results 1 to 7 of 7
    Jul 2003
    276
    Stepper rough 1 direction
    As you can tell I am new to steppers!
    But what would make a stepper driven by a PicStep driver smooth in 1 direction but rough in the other?
    Mar 2005
    8
    Question My first post
    Hi all,
    I have the same problem.
    Any idea to solver this?
    Thanks.
    May 2005
    1810
    Someone - help these guys out!! (just a post bump to help out!!)
    Mar 2005
    8
    Talking Working
    Now is work fine after change PIC.
    With unloaded stepper motor (HT23-400 264oz-in, 2.8A),
    I can turn 300rpm without any resonance (8micro-stepper).
    Very nice board and firmware.
    Thanks Alan.
    Sep 2004
    223
    Quote Originally Posted by Lucas-10
    Thanks Alan.
    Hi, Glad you figured it out. I've been busy and not looking around the forums much these days.
    One thing, what revision PIC16F628As did you use? I'd be interested in knowing the revision numbers on these PICs that work and don't work, maybe there is a bug in their construction that is effecting the PICSteps performance that Microchip has repaired/replaced. I've used 30 or so 16F628As and never had any issue, but globally you never know!
    Cheers,
    Alan.
    Mar 2005
    8
    Hi Allan.
    I use old parts from another board (crap board)
    and can’t read revision numbers, sorry.
    I bought 3 new PIC’s and its work very fine.
    Thanks.
    Mar 2005
    523
    if the motor workes fine in one direction and the the other the only think ( i think ) it can be is software in the microcontroller or pc software ( that is if u r using a 4 pole stepper, if it is a 2 pole it coule be the above plus a flakey drive transistor
  1. Help with LPT Stepper Interface
    By nickleplated in forum Stepper Motors / Drives
    Last Post: 06-09-2005, 01:28 AM
  2. Not good for a stepper motor?
    By FLUTE HEAD in forum Stepper Motors / Drives
    Last Post: 12-02-2004, 06:31 AM
  3. z axis direction question.
    By ljoe1969 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-22-2004, 02:53 AM
  4. Fun with floppy stepper and driver
    By Konstantin in forum CNC Machine Related Electronics
    Last Post: 03-08-2004, 08:18 AM
  5. disassembly of stepper motors
    By dhprc2 in forum CNC Machine Related Electronics
    Last Post: 06-26-2003, 01:09 AM
