586,651 active members*
2,862 visitors online*
    Mar 2010
    Big Block Chev Bellhousing Dimensions
    Hi All, was wondering if anyone might have a CAD file or drawing of the bolt up pattern for a Big/Small Block Chev Bellhousing
    Feb 2007
    4553
    Post
    HCD,
    See attached image for dimensions.
    Hope this helps,
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Mar 2010
    Thanks Jeff I'm drilling a twin bigblock engine plate with an auto dropbox. Do you have a drawing that would be dimensioned to 3 decimal places as I need a bit more accuraccy. Drawing suppled is a great help. CHEERS!
    Jun 2006
    11
    Quote Originally Posted by hellcycledoctor View Post
    Just write a zero at the end of each of the supplied dimensions and you will have the accuracy you want.
    I have used the small block version of these prints to make adapter plates etc and they work perfectly.
  1. CAD drawings of most popular V8 engine bellhousing patterns
    By FPV_GTp in forum MetalWork Discussion
    Last Post: 02-19-2024, 03:09 PM
  2. 1/6th Chev 327
    By DSL PWR in forum I.C. Engines
    Last Post: 02-22-2009, 08:44 PM
  3. TL2 Dimensions
    By AMCTony in forum Haas Mills
    Last Post: 11-22-2006, 06:57 PM
  4. RS232 program block by block
    By smoregrava in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-22-2005, 07:52 AM
  5. CPU water block dimensions
    By DAB_Design in forum Computers / Desktops / Networking
    Last Post: 03-26-2005, 01:29 AM
