587,771 active members*
3,403 visitors online*
    Sep 2007
    356
    Axis rebuild on lathe
    I decided it was time to rebuild the x and z axis on my lathe. I found that I have metric acme lead screws. Is this common on import machines? They look to be 12/3 or 14/3 on the x axis and 16/3(?) on the z axis. The nuts are made of either brass or bronze? My biggest problem/question is do I use the metric lead screws and buy metric acme taps for this project or try to make new ones using american pitch threaded rod? Second question what do I use for the lead screw nuts? I have some brass and oil impregnated bronze, but I don't know which will hold up better.
    May 2008
    110
    IF you change the screws from metric to imperial you will have some gear changes in your threading gear box. I would not use oil impregnated for the half nuts it is a little soft,
    budP
    Dec 2004
    1865
    Quote Originally Posted by budP View Post
    budP
    Not to mention if you have graduated dials on each axis, they will not read properly when you change screws.
    Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out.
    Sep 2007
    356
    Well I went ahead and bought metric taps. Would bronze be better to make the nuts out of?
  1. Rebuild of an very old Aciera F3
    By syyl in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 09-01-2008, 07:17 AM
  2. rebuild help
    By houdini in forum I.C. Engines
    Last Post: 04-14-2008, 02:16 PM
  3. rebuild
    By corrie in forum CNC Wood Router Project Log
    Last Post: 03-20-2008, 10:29 PM
  4. Haas Vf-2 Rebuild
    By DEAN in forum Haas Mills
    Last Post: 09-19-2005, 04:46 AM
