Originally Posted by
bitbanger
I'll comment because I know you will likely not get much response, as this is a brand new product.
This basically accomplishes the same thing as an opto-isolator, except the isolation chips use radio frequencies, rather than light to perform the isolation.
What is nice is that the PC side can be powered from USB, and there is an on-board regulator for the logic side of your drivers, as well. On-board pull-up resistors for your limit switches, and a non-isolated e-stop input (so that e-stops get signaled regardless) make this a really nice board.
>Len
