587,770 active members*
3,087 visitors online*
Results 1 to 7 of 7
    Oct 2005
    162
    Where can i find metal lathe spare parts in brisbane?
    Gday,
    i am starting to build a cnc lathe. most of it will be scratch built (because i want to) but i want a collet spindle and a couple of other things (don't know yet, but once i am started i'm sure i'll think of something). anyhow, does anyone in australia (preferably Brisbane) know where i can salvage lathe parts for my own personal use?
    any help would be very much appreciated!
    Rhino.
    Dec 2004
    411
    Try Hare & Forbes 07 3274 4222. They also have branches in Melb and Syd.
    Or ... Emco 02 9648 4377
    Or ... purchase Australian Model Engineering from your newsagent and place an ad. in that magazine
    Good luck
    Andy
    Drat, imperfection has finally stopped working!!
    Oct 2005
    162
    No such luck! looks like i'll be making the spindle my self. at least i'll be able to determine the spindle bore myself.
    Jun 2005
    17
    Have you seen the Dave Gingery books? He has a set of plans for scratch building your own machines (manual machines, that is!) He also suggests casting your own pieces.
    Apr 2003
    131
    I've heard you can yank the spindle out of a 5C spin indexer for this. Depends on the size of the lathe you want...
    Apr 2003
    372
    Rhino,
    You could try Minitech, they are in Brendale.
    "A Helicopter Hovers Above The Ground, Kind Of Like A Brick Doesn't"
    Greetings From Down Under
    Dave Drain
    Akela Australia Pty. Ltd.
    Oct 2005
    162
    thankyou for your replies. will get on it 2morrow!
    On the other hand, You have different fingers.
