587,761 active members*
3,134 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Y axis does not move in manual mode control Fanuc 6MB
Results 1 to 7 of 7
    Jun 2011
    I have a four-axis Bridgeport horizontal milling with FANUC 6MB Control, I can not move the Y axis, review the diagnosis # 97 bit 4 (* ITY) = 0,
    Check electrical circuit and are pins that are not being used as the other axes, then do not understand why this to 0 and what is the procedure to put in 1.
    once when I turn on the machine, the diagnostic # 97 bit 4 occurs in 1 but becomes 0 after a time
    Any help or suggestions will be helpful
    Regards
    Nazario
    Apr 2009
    1379
    That is the interlock bit for the Y-axis.
    1: the connection board has a bad input
    2: there is a wiring problem up to connector C03 pin 35 on the connection board
    3: an external signal connected to connector C03 pin 35 on the connection board is incorrect (see the electrical diagram)
    Jun 2011
    check the wiring diagram, C03 pins 34, 35 and 36
    these pins are disconnected (no use)
    also check the cables, these are loose
    Regards
    Nazario
    Apr 2009
    1379
    then the *ITY input should always be a "1". Looks like you have a bad connection board. We have a spare that we can sell you.
    Jun 2011
    I have the replacement for this board, set the jumpers as the one in the machine and replace the board but the problem is not solved, any other option to solve this problem.
    regards
    Nazario
    Apr 2009
    1379
    jumper connector C03 pin 35 to pin 33 (+24) and monitor diagnostic # 97 bit 4 (* ITY). and diagnostic # 33 bit 4 (* ITY) is the same; but diagnostic # 97 bit 4 (* ITY) is only used if the control has a PC.
    Jun 2011
    diagnostic # 33 bit 4 = 0
    diagnostic # 97 bit 4 = 0
    when you place a jumper between pin 33 and pin 35 of C03
    diagnostic # 33 bit 4 = 1
    this means that the diagnostic # 97 bit 4 is controlled by the PC?
    if so, what can be the source of this problem?
  1. Help! Mach 3 Won't Move my Stepper Motor - Emergency Stop Mode
    By AntonCNC in forum Machines running Mach Software
    Last Post: 03-08-2017, 02:38 AM
  2. Replies: 1
    Last Post: 03-18-2011, 10:25 AM
  3. Looking for manual for a Fanuc 11 Control
    By TweedFab in forum Fanuc
    Last Post: 02-24-2010, 02:32 AM
  4. FANUC O-MD Control MAnual
    By m_bhui in forum Mastercam
    Last Post: 11-04-2008, 05:58 AM
  5. Rapid move axis control
    By mattpatt in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 08-15-2008, 03:51 PM
