587,913 active members*
3,881 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki Mills > mori seiki 9000 programs won't unlock
    Jan 2014
    I am trying to edit a tool change macro on a Mori horizontal with an MSC502 control. When I attempt to change the parameter 3202b4 I am given a "write protect". Write enable has been turned on. I am able to unlock/lock the 8000 parameters, but not the 9000 following the below process:
    Mode=mdi
    parameter write enable = 1
    parameter 3202b0 = 1 or 0....Works fine, no alarm
    parameter 3202b4 = 0...Write protect alarm
    This is the first I have run into this on a Fanuc control. Is there a way around this?
    Thanks in advance.
    Feb 2009
    6028
    3202 is the correct parameter (NE9), I have over a dozen newer Moris here that will allow that parameter change, no extra write protects other than the PWE, and the panel key switch. Try doing it in E-stop.
    Aug 2011
    Re: mori seiki 9000 programs won't unlock
    How did you manage finally?
    I am facing the same problem with Fanuc Oi M
    Please suggest
    Martin
  1. 9000 programs?
    By jimmyjolly in forum Fanuc
    Last Post: 04-20-2023, 07:02 PM
  2. Replies: 5
    Last Post: 04-12-2014, 08:22 AM
  3. Mori Seiki JR PLC programs
    By Nikola in forum Mori Seiki Mills
    Last Post: 11-01-2010, 09:44 PM
  4. need to unlock 9000 series programs
    By rhutch in forum Fanuc
    Last Post: 04-10-2010, 06:51 AM
  5. 9000 programs
    By crazycnc in forum Fanuc
    Last Post: 12-21-2008, 12:20 AM
