You're better off taking the manual route first. Personally, I've never seen a shop that would take someone in off the street with no experience and put them directly on the CNC's. They almost always start off burring parts, doing secondary's on manual equipment, etc. You can't have a good understanding of CNC's unless you have some concept on how to make the part manually. For example, you'll never understand the difference between cutting aluminum and 300 series stainless until you try to run an endmill through each on a Bridgeport(that handle turns hard in stainless, don't it) But now put a corncob rougher in ther that's made for stainless and it cuts so much easier now doesn't it. These are the same forces the CNC's are working against and you wouldn't know unless you had felt them for yourself on the Bridgeport. Besides, a good CNC guy is going to need to know manual machines to make fixtures, custom tooling, etc. In the meantime, I agree with Fran H about the Cad/Cam deal. I would get a student version of MasterCam or SurfCam and try to learn it in parallel with your manual training. Oh, and don't forget this forum. There's a lot of info out here.... Good luck!
:cheers:
I don't know much about anything but I know a little about everything....
