587,259 active members*
3,035 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Quick and Easy CAM for one-off?
Results 1 to 11 of 11
    May 2005
    2
    I am new to CNC. I have been designing a lot of parts that I'll be creating only one of, or parts that I might create a couple of, but want to proto out real fast.
    I've played with a couple CAM packages, but they seem like a lot of setup. I'd like to find a CAM package that allows me to generate toolpaths quickly, but still returns good results. I realize the more complex you get, the better toolpaths you can create.
    Most of the work will be 2.5D, primarly 3 axis routing. I may dabble in 3 axis milling in the near future. Some of it will be just cutting, some will 2.5d parts, some creating from raster, like photos, engraving, etc.
    Please do not count price as a factor. Obviously I like cheaper, but I'm looking at all angles.
    In short, I do 3axis, 2.5d work on a cnc router. I am looking for a CAM that will take my CAD drawings, and with minimal setup, output good quality to gcode.
    Thanks for the insight!
    Mar 2004
    1543
    I've never used this. But sounds like your interest.
    http://cadem.com/camlite/camlite.htm
    Karl
    Jun 2003
    205
    Easy CAM
    Maybe something outside the "cad/cam box" ... KipwareM ... www.KentechInc.com
    4826
    OneCNC XR Mill Professional
    May 2005
    2
    Thanks for the insight all! I'm continuing my investigation. The Cadem software looks especially interesting. =)
    Sep 2003
    111
    If you are interested in machining from raster images and virtual sculptures, you might want to take a look at VS3D. Of course, I'm a bit biased since I wrote VS3D. Here is a tutorial showing the carving of a raster image in VS3D:
    http://www.designscomputed.com/vs3d/...mg_emboss.html
    Daniel Carr - President,
    Designs Computed, LLC
    Aug 2004
    2849
    Oh, that is so tricky Cadem versus Cadam......Cadem is in Banglore and Cadam is French....in fact I think IBM started Cadam....anyway.
    Mar 2004
    847
    Quote Originally Posted by HuFlungDung
    I second that! They seemed to have put a bunch of new movies on their website too!
    Check Out My Build-Log: http://www.cnczone.com/forums/showthread.php?t=6452
    Aug 2004
    2849
    Isn't OneCNC up in the megabuck range??
    4826
    Quote Originally Posted by ViperTX
    Heck no, kilobucks, yes
    He said not to use price as a determining factor. In reality, if anyone out there is serious about machining at a profit, OneCNC is actually inexpensive. Admittedly, you do feel like you're taking a risk to start with, but afterwards, you'll wonder how machining is done with less capable softwares.
    Jun 2005
    53
    I have been using OneCnc for about a year and a half now . OneCnc XP was very good for the price but, OneCnc XR is AMAZING. It is the easiest and best modeling software at any price in my opinion. If you are going to do alot of 3D machining get it. As far as the graphics (both simulation and part modeling) - they are the highest quality that I have ever seen (including Mastercam). Price is ALOT less than Mastercam. It is not HOBBY software so it isnt going to be cheap either.......
    Patrick
  1. New Basic CAM Software e-NC http://www.easymill.com
    By Stephan Hales in forum News Announcements
    Last Post: 04-10-2010, 10:00 AM
