587,913 active members*
3,984 visitors online*
Results 1 to 8 of 8
    Feb 2005
    487
    Bridge Port Series II CNC for sale
    Hello,
    I have a BP series II CNC, It is in excellent shape, with Ballscrews on all three axis, Chrome ways (can still see all the "Frosting") on the ways.
    It also comes with 3 Allen Bradley 1326 DC servos, 42"/LBs, with 3 Rutex 200V 40A drives on mother board, Avel Linburg Transformers, Caps and encouder connectors/cabnet.
    All for 6K, (this is the same machine that was at the CNC Workshop 2, that the Pico servo guy was demoing his drives on). You will have to pick it up, and supply a fork truck to load it. You can look at it, if you want email for appointment.
    Please, serious inquires only.
    email me at (change the "at" to @): [email protected]
    Mar 2006
    93
    hi i just bought a bridgeport 2 and got it running BUT maybe you can help me .when i turn it on it shows power interupted. i push deleate. then it shows manual operation. pass over z,x and y.i then push the power button then start zlocates and deletes from screen then x does the same, then y locates but doesn,t drop off screen for about 1minute 1minute later gross positional error comes up. i have checked the y axis and nothing is blocking movement???? any ideas thanks Dar
    May 2006
    202
    DAR, When you first power up you will get the power interruption error. Hit the CE button and then it will ask you to clear the axises. Hit cycle start and the Z will retract and clear on the screen, then hit cycle start again and the Y axis will move forward and clear, then hit cycle start again and the X axis should clear. At this move use your manual controls to move the X & Y axis off the Reference points, or toward the middle of the axis. If they won't move you may have to push and hold the power button while moving the axises. Once center zero out the axises. Hope that helps you.
    Ben
    1121
    re
    Dar:
    try starting a new thread, title it with heidenhain[your control I presume]
    y axis moves? might be tach or encoder problem, or if it homes the y towards the column, it may just have crap in the way
    Nov 2004
    3028
    And if it does not move, you may have a bad drive or motor. Try moving the belt by hand to make sure nothing is jammed. Then swap the motors if it is NOT moving, then the axis drive. If moving you may have a bad switch or a bad encoder (swap motor).
    George
    Mar 2006
    93
    Question bp2cnc new problem
    thanks for the info guys come to find out the rubber on y behind the table was about afoot to long so it wadded up and stopped the movement. now though when i try it the z axis moves down instead of up. any ideas?
    thanks again Dar
    Nov 2004
    3028
    The Z moves down to come off the switch, then reverses direction to come back up. If the switch does not change state (stays open) it will continue going down. Check the switch and wiring.
    George
    Mar 2006
    93
    bp 2
    thanks for the info George . checked them all then found i had a couple of the parameters reversedi guess you can,t do that anyway it,s running fine now . i just have to learn how to pro
    gram it thanks again to you and Ben
  1. What is the Difference between 6000 series aluminium and 7000 series
    By Kosta1234 in forum Material Machining Solutions
    Last Post: 05-02-2018, 04:02 PM
  2. Bridge Port Clone CNC conversion
    By happymarius in forum Employment Opportunity
    Last Post: 01-22-2007, 01:56 AM
  3. Bridge port series II NC 1973 Retro help
    By astro02 in forum Bridgeport / Hardinge Mills
    Last Post: 01-04-2007, 06:30 PM
  4. Bridge Port Textron opreating mannual required..
    By Danii in forum Bridgeport / Hardinge Mills
    Last Post: 08-10-2006, 09:43 PM
  5. Bridge Series II CNC,Boss 6. Begging for Help
    By Jerry7 in forum Bridgeport / Hardinge Mills
    Last Post: 02-19-2006, 07:48 PM
