:banana:
LC1290 laser engraving machine
The unique decelerate design make the mechanical system move stably and smoothly. The edge of cutting is smooth and there is no sawtooth. The software adopts. continuous curve method to get faster cutting speed.
Specification:
Laser- type:Sealed CO2 laser tube
Laser power: 80W ,100W,130W,150W,200W (GSI) (optional )
Cutting area:1,200 x 900mm
Whole machine size:1,720x 1,210 x1,070mm
Cutting speed: 0 -24,000mm/min
Resetting positioning accuracy: ±0.05mm
Working voltage: AC 110 - 220V±10%, 50 - 60Hz
Gross power: <1,200W
Operating temperature: 0 - 45℃
Operating humidity: 5- 95%
Graphic format supported: BMP,PLT, DST, DXF, and AI
Driving system: stepper
Cooling mode: water-cooling and protection system
Auxiliary equipments: Exhaust-fans, air-exhaust pipe
Controlling software: DSP control system.
Compatible software: CorelDraw AutoCAD Photoshop
Net Weight: 280kg
Applicable materials:
wood, organic glass, plastic, garments, paper, leather, rubber,and other nonmetal materials.
Applicable industries:
advertisement, arts and crafts,shoes,toys, computerized embroidery and clipping, garments,model and construction industry.
SKYPE:wkquiven
[email protected]
